Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options MenuPlease select an option:
Safe ModeSafe Mode with NetworkingSafe Mode with Command Prompt
Enable Boot LoggingEnable VGA modeLast Known Good Configuration (your most recent settings that worked)Directory Services Restore Mode (Windows domain controllers only)Debugging Mode
Start Windows NormallyRebootReturn to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
5 questions posted
2 Questions
