20 Most Recent
Polaroid Digital Instant Mobile Photo Printer, PoGo - POLAROID Questions & Answers
How can a Polaroid Pogo printer works without battery, directly connected to current?
If you a reasonably handy you could disassemble the battery pack and replace the cells with new NiCad or NiMH units. They are not complicated and you should find lots of sites on the net that will supply the cells. Alternatively if the unit has a DC socket you should find the voltage and current printed beside it. Try fitting a suitable power pack.
Cant sign in
Sign in to what/where? You obviously managed to sign in to FixYa.
My ea games load but the will not play
make sure you have the software that you need to play them such as direct x is a software you will need to play tons of games on your computer that you installed from a cd.
Pogo ican get on pogo but most of the games will
Remove all Java and Flash from your computer. Once removed, do a Shut down, wait a couple of minutes, power the computer back on, go to Adobe and download and install Flash, after that's done, go to
www.java.com and download and install the latest version of Java. Restart the computer, then try Pogo again. Don't skip any of the steps or it probably won't work.
Pogo printer error -21860
Don't name files with characters like - . & or something like that.Hope that the tip will be useful.
Snap. Why won't it turn off?
There is no such external reset buttons to modern TVs. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
