20 Most Recent HP Photosmart 7520 All-in-One Color Inkjet Printer - Black Questions & Answers
My Automatic Document Feeder for my HP Photosmart 7520 won't work
Does it grab paper at all? Does the paper jam in the doc feeder? does it scan when place on the glass? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/29/2021 8:19:20 AM • HP Photosmart... • Answered on Jul 29, 2021
Hp 7520 carriage slams back & forth and then says it is jammed but can be moved freely
Hi Going to resurrect this old thread as my experience may be of some use. My HP 7520 kept coming up with error 0x610000f6. You could hear the carriage moving and clunking as it hit the end stops. Thought it was probably the encoder strip or sensor took the printer apart and cleaned / checked both looked ok. reassembled the printer still no joy. As I had the sides off the printer I noticed that the ink catch / cleaning tray seemed to not want to move (mentioned in post above). with the side off the printer it is easy to move the tray. After a bit of wiggling the printer booted up ok. It still errors every now and then but again a bit of fiddling sorts it out until next time. I should strip it down and find the problem but as the whole ink trak is filthy I cant be bothered. Maybe if it gets worse I will if I do I will post some pictures. Here is what you need to do to check the ink tray: Open the lid as if you were going to change cartridges. Does the carnage move freely? If not then you probably have a different problem. On the right hand side (opposite the screen) there are two torx screws you can now see under where the lid was. Remove these. Remove the ridged plastic band that runs around the bottom right hand side of the printer.Start at the front lever the top left hand corner out with a small screwdriver. Whilst holding this out slide the front section to the right. Once this has unclipped pull the whole ribbed piece of plastic forward. Now the ribbed plastic band should come away. Remove the side panel that the two screws held in place. Now you can see into the printer. Close lid and turn on and look and see what happens. If the carriage moves from side to side and hits the end stop on the open side of the printer but the small white gear under the ink tray does not move then it is jammed as mine was. Turn off printer. Open lid again. move carriage out of way. Put some disposable gloves on. Where the carriage stops on the right had side it pushes a small lever. Push this with one hand with the other hand gently move the ink catch tray back and forth. Once it is moving ok pus back to back position. Close lid power on. Hopefully that will sort it out? Spent ages looking on the internet for a solution this thread was the closest I found, amongst all the HP junk telling me I had a paper jam. Hope this is of use to someone.
2/12/2019 10:23:09 AM • HP Photosmart... • Answered on Feb 12, 2019
2answers
My HP 7520 printer isn't printing right. The black comes out looking like a negative. I have all new ink cartridges-what's going on?
This video shows how to troubleshoot printed image quality.
11/26/2018 11:05:05 PM • HP Photosmart... • Answered on Nov 26, 2018
2answers
How Ink system on my HP photosmart 7520 printer is broken, it displayed what do I do?
Try removing the printhead and cleaning the contacts on the printhead. To remove the printhead, see this video instructions:
11/6/2018 4:50:14 AM • HP Photosmart... • Answered on Nov 06, 2018
2answers
My printer will not print
Try reinstalling the device driver. You can find the device driver here: HP Photosmart 7520 All in One Printer Software and Drivers I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
3/16/2017 11:09:31 AM • HP Photosmart... • Answered on Mar 16, 2017
2answers
Unable to clear missing/damaged cartridge msg even after cleaning.
why does my printer say ink cartridge missing or damaged ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues Aug 8, 2012 - 10 posts I recently changed my ink cartridges ( colors and black) and now it says that the ... why does my printer say ink cartridge missing or damaged? ... cartridge from Office max and it still has the message and I am unable to print. ... Remove the cartridge and take a close look at the tiny circuit card on the section ...
11/30/2015 1:24:30 AM • HP Photosmart... • Answered on Nov 30, 2015
The printer won't start up after inserting new HP cartridges. It says the print head is misinstalled,
Guess your prineter is defective. If you don't know how to repait it, you should take it to anauthorized HP service
8/10/2015 11:30:40 PM • HP Photosmart... • Answered on Aug 10, 2015
Error code 0x610000f6.. would this be related to refiled cartridges
Hi paschal karl The error code you are seeing may or may not have to do with the cartridges being refilled. Here's the thing, yes, you can refill your cartridges or use re manufactured cartridges, but you may run into problems. QualityLogic, one of the world's foremost quality assurance organizations, tested the performance of HP inkjet print cartridges vs. re manufactured (refilled) brands. The results: original HP inkjet print cartridges far surpassed ink refills in both print quality and reliability.
  • Nearly one out of every six refilled ink cartridges tested was dead on arrival or failed prematurely
  • 70% of refilled cartridges had some form of reliability problem
Count on HP original ink cartridges for consistent, worry-free printing. You may think you're saving money on re manufactured or refilled ink cartridges, but in the long run, the cost of wasted time, ink, and paper can more than make up the difference. -Source Most people think, 'well of course that is what HP or an HP representative would say', but I have done some research and found that many others have too. Here is a perfect example of somebody who does not work for HP in any way and basically is a customer advocate (in my opinion) ;Should you refill your printer's ink cartridges? HP says no (of course) By Matthew Murray I found the above article interesting and genuine. To summarize, again, yes you can refill the cartridges. The printer is not programmed to reject them. Sometimes the cartridges will not work and of course because they are non HP, HP would not be able to do anything to help. HP cartridges have a 2 year manufacture warranty;Limited Warranty for HP Ink Cartridges and Customer-Replaceable Printheads for HP Inkjet Supplies, this may give you comfort knowing HP stand behind their product. Perhaps you will find the following document helpful: HP Printers Problem with Printhead Printer Failure Ink System Failure or... I hope this helps. I work on behalf of HP.
7/6/2015 3:35:36 PM • HP Photosmart... • Answered on Jul 06, 2015
Power is on but the printer display won't turn on.
unplug the printer power supply for about 10 seconds, the plug back on, i have to do that to my wifes printer ever so often, most usually right after a power outage.
4/1/2015 9:50:52 PM • HP Photosmart... • Answered on Apr 01, 2015
2answers
Why does my 7520 printer print old documents.
Your computer has "queued" various pages to be printed. When it detects that it cannot completely complete the output, it restarts the sending of the information to the printer. From the Windows "Control Panel", select "Printers". Select your printer. Click to "show what is printing". From there, you can select an item, and choose to "cancel" it.
3/2/2015 4:29:11 AM • HP Photosmart... • Answered on Mar 02, 2015
How do I instal ink cartridges in my hp 7520 printer
Hi, very easy to replace the inks in your printer. If you fold up the entire top section, the ink print heads will slide to the left revealing the seated inks. Change the inks and the slider will got back into place once the cover is closed. If you ever need to replace your inks in the future, please email me. [email protected]. Great deals on inks; less expensive the Staples and Office Depot. Visit us at www.iprinttechnologies.com. I am always happy to help.
2/25/2015 10:03:15 PM • HP Photosmart... • Answered on Feb 25, 2015
How do I install a new ink cartridge?
Go to this link. Go to page 44 of pdf (43 of document). http://h10032.www1.hp.com/ctg/Manual/c03456524.pdf
1/20/2015 11:27:08 PM • HP Photosmart... • Answered on Jan 20, 2015
Does startup ink cartridge have to be replaced after it is empty
Yes if you want the printer to print. Many printer makers are using startup carts now so you will buy the new ones soon. I would wait until you can no longer put up with the warning message or it runs out of ink to replace the cartridge.
12/25/2014 11:03:52 PM • HP Photosmart... • Answered on Dec 25, 2014
Prints and/or copies only 2/3 page
Check to be sure that you have the paper size selection and orientation correct.
12/25/2014 3:16:47 AM • HP Photosmart... • Answered on Dec 25, 2014
HP Photosmart 7520 All-in-One Color Inkjet Printer - Black Logo
67 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
printer start up after inserting new hp
  • Office Equipment & Supplies
