20 Most Recent
Sunbeam Ultrasonic 81696 Humidifier Questions & Answers
Does the Sunbeam Ultrasonic Humidifier Model 696-12 have a filter?
This humidifier is AMAZING. I’m a huge fan of using essential oils (lavender, lemongrass, spruce, rose, sandalwood etc) and I picked this up from a thrift shop, added some essential oils to the water and my house smells wonderful.
Essential oil diffusers are virtually the same thing design wise except cost a fortune. This is my best diffuser! I paid $10 for it and it works so good, throws off a ton of mist which I love (it’s so dry here) and I will enjoy owning this unit for years to come. Only thing is to gently clean the little ionizer part with the brush gently and keep it clean. Also..this unit unlike newer ones does NOT shut off automatically so keep an eye on it. Running it dry might cause it to burn out.
12/17/2017 2:09:34 AM •
Sunbeam...
Answered
on Dec 17, 2017
Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
2/11/2016 3:16:52 PM •
Sunbeam...
Answered
on Feb 11, 2016
I just bought this product and the filter meter
No, it's not normal not to feel or see any mist coming out. Depending on your home's water supply may have presented the problem. Especially if it's well water ... to many minerals. Which will clog the filter. Or your city water supply may be the same.
In any event, I would suggest buying and installing a new filter and using Bottled Distilled water instead. It's inexpensive ... about $1.00 per gallon.
If that doesn't solve your problem, return the unit under within the Warranty Period for replacement of repair.
2/9/2011 4:10:20 PM •
Sunbeam...
Answered
on Feb 09, 2011
Giving of smell, what to do?
Sorry to read about your problem, I hope this helps you out.
try putting some white vinegar in the unit like a cup with water, let run a while, then put fresh water in
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/21/2010 6:03:45 PM •
Sunbeam...
Answered
on Dec 21, 2010
Sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time.
These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
12/18/2009 11:37:33 PM •
Sunbeam...
Answered
on Dec 18, 2009
Sunbeam Ultrasonic Humidifier 696-12
tentative on the Solution icon ...
I picked this up a couple days ago at the Salvation Army, 3 bucks. I also had way too much damp coming out, saturating anything near.
I read through the comments, and one folk said they uncovered the spaz unit and tightened the screw they found there, to no avail. They asked if they should reopen and loosened the screw ...
Which I did. Took me a while, and maybe those who aren't used to investigating the inner workings shouldn't try it unless they're willing to make a mistake and throw it away, but ...
I loosened the screw. Not sure if it was a quarter turn or a half turn; I wanted to do more and have learned many times that "more" is not "better."
I have a cardboard box in front of the unit for hours now, and it is not saturated.
The factory setting, whether it be for all or some, is too wet. Loosening the screw that shows through the computer board has, for me, made the unit more tolerable. Takes an eyeglass-screwdriver to get it done, but if'n ya has the general know-how to investigate things, maybe it'll work for you.
1/11/2009 7:43:29 PM •
Sunbeam...
Answered
on Jan 11, 2009
