20 Most Recent
Price Pfister 042-YP0E Ashfield Single Handle 4-Inch Lavatory Faucet with P Questions & Answers
I just had a new price pjister series 40 (Ashfield
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Hot water side of a 42 ashfield faucet allows very
You will need to take the faucet apart and clean it out. If the faucet is a few years old I would just replace the cartridges and be done with it.
When the water heater was replaced the lime build up in the piping was dislodged and I bet the faucet you are having a problem with was the first faucet used after the new water heater was installed.
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
MY PRICE PFISTER 533-50 HAS
No be sure water is off. Take this apart with still being supplied will cause you a lot of trouble, wife will be very unhappy.
I have a slow drip on my bathroom faucet. how do i
Full instructions with diagrams here:
http://home.howstuffworks.com/home-improvement/plumbing/how-to-repair-a-faucet1.htm
very detailed and should help you stop that annoying drip..drip...drip
Hope this helps, if so please leave feedback. If not let me know and I'll try and help some more
What causes noise when water turns on
are you speaking of water hammer ? as typically this occurs when shutting off water , faucets that make noise like a whistle when on could be a part clogged aerator in the end of it , this happens over time and debris is aloud to collect in end of faucet
