20 Most Recent
PC Chips M825G Motherboard Questions & Answers
PASSWORD RECOVERY
Try to Recover Excel Password with
Excel Password Recovery 5.0. I have searched MS Excel Password Recovery, found this efficient Excel Password Recovery program. It supports all versions through 97 to 2007.
Remark:
Office Password Recovery tool also can help! It recovers Password to Open and removes both the Password to Open and Password to Modify for Microsoft Word, Excel, Access and PowerPoint of versions through 97 to 2007.
M825G motherboard
Max ram is 2GB
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=24&LanID=0&DetailID=283&DetailName=Specification
My ECS M825G motherboard has no battery? that I
All motherboards have what we call a RTC battery. This means Real Time Clock which keeps the time and date and also the BIOS setting while the computer is turned off.
Look at the picture below for what the battery looks like and you should find it with ease >>>>
Regards.
Pc chips m825 v 7.2
check if you new processor is compatible for you mother board..if it is compatible, try reinsert the RAm or replaced it with a new RAM...hope it helps you..
Can i upgrade the memory chips so my i tunes
go to www.crucial.com and click on 'scan my system'. It will tell you if you can increase the RAM.
here are the specs
• 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR333/266/200)
• Maximum memory : 2GB
It may be your video card, this is an old low end motherboard so it will struggle playing HD movies.
I can't install a cpu heat sync because my mobo
from what iv found out looking at picks are you sure you have the right heat sink (there are diffrent ones out there) you need to have one for a socket A they are very hard to get hold of new and anything with out that on will NOT fit found all this out when i had to replace mine
