20 Most Recent
Jura Impressa X9 Espresso Machine Questions & Answers
My jura x9 says rinse fill
This happens when the machine is priming the thermoblocks(heaters) the machine is not registering water flow through the machine.blockage in water tank? pump not running? a thermoblock scaled up(blocked). first check the 2 flow meters in the machine located under the water tank. one of these may be defective or just stuck,
Milk does not come out
remove the milk hose and the dispenser. grab the dial that lets you change between milking a cappuccino and a flat white, pul is straight out of the removed section. You will find slots in the shaft that are choked with milk solids. This happens when CAPPY RINSE is ignored.
Machine constantly saying "clean now" even directly after a cleaning
The machine continues to say clean now after a clean if it hasnt been competed corrected or interrupted. A cappuccino clean wil not clear the message you have to complete an entire clean the milk and the coffee brewer. an internal leak on to the drip try contacts will also give problems. If you require addition help let me now ...
Jura impressa x9 classic.
this problem is normally due to the flow meter not sensing water flow through the machine. possible causes are 1,lime scale in the thermoblock this may need replacing. 2, the pump has failed also may need replacing. 3. the flow meter itself is stuck , this can be dismantled and cleaned, if not then replacement is required. 4. a simple blockage from the water tank to the inlet . not a job for the novice..
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
