20 Most Recent Maax Breeze: One Piece Round Shower Without Roof Cap but with MAAX IES 1/2 Questions & Answers
2answers
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc. When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough. It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate. After filling the traps with water or water & oil, just ventilate and you're done!
4/29/2016 6:15:57 AM • Maax Breeze: One... • Answered on Apr 29, 2016
Is there any problem with using silicone on maax mediterrian III shower walls
I looked at the installation instructions for mediteranean III at this Maax site. It says silicone sealant is to be used. Unsure where you noticed mentioned of siliconized latex. http://www.maax.com/en/products/showers/showers-kits/mediterranean-iii-tm
9/4/2014 1:06:35 AM • Maax Breeze: One... • Answered on Sep 04, 2014
The double roller assembly on
That part is Maax only, you will need to go through them or a dealer in your area.
http://www.maax.com/Corpo/DocumentsTechniquesCorpo.aspx
3/6/2011 10:19:44 PM • Maax Breeze: One... • Answered on Mar 06, 2011
The roller mechanism from my shower door broke. I
model# is 100135, for parts try web search-max breeze 100135 parts
10/9/2010 12:48:49 AM • Maax Breeze: One... • Answered on Oct 09, 2010
Maax Rainforest shower model 4343. Where do I find a cartridge for it please?
Question edited for clarity. Combine 3 posts into 1 Post. Delete two duplicate posts. Refresh page to see your question. Better to order direct from Maax to be sure of the part and get warranty. They are expensive. Model 4343 doesn't appear to be a valid product https://www.google.com/search?q=Maax+Rainforest+shower+4343+parts
Shower And Door Replacement Parts - Maax
Maax https://maax.com > services > replacement-parts You can now buy shower replacement parts for MAAX showers, doors and kits online. Shop Now. Find the replacement part you need. Missing: 4343 ‎' Show results with: 4343
MAAX Canada https://maax.ca > services > replacement-parts You can now buy shower replacement parts for MAAX showers, doors and kits online. Shop Now. Find the replacement part you need. ..
4/17/2024 9:35:22 PM • Maax Plumbing • Answered on Apr 17, 2024
MAAX Saninova control panel
To find out more about replacement components, get in touch with MAAX directly or go to their website. You might be able to obtain the precise control panel you require from one of their authorized dealers or distributors.It will ensure you get an original one
8/14/2023 11:44:32 AM • Maax Plumbing • Answered on Aug 14, 2023
2answers
Do I need to Cement under my Maax shower pan? 60 x42, 3 height
This video doesn't show needing cement - Maax Professional Installation Video KDS Series
7/11/2018 10:03:04 AM • Maax Plumbing • Answered on Jul 11, 2018
My maax pivolok door wont fit in the opening they said to make it
and what is your question --if you want to complain notify the company
4/30/2018 1:26:46 PM • Maax Plumbing • Answered on Apr 30, 2018
How to change overhead light in maax shower?
There are 2 types of litghly cover. A twist off (1/4) turn and a some pry off. It shouldn't be required hi torque. Try twist off first counter clockwise
6/2/2017 10:01:33 PM • Maax Plumbing • Answered on Jun 02, 2017
Drain stuck in closed position
Generally the drains that are controlled from the OVER-FLOW do indeed have a rod that goes down from the face of the overflow... which lifts (opens) the drain by lifting a hollow (typically plastic) sleeve from in front of the outflow of the drain... It is hollow to allow the OVERFLOW to work at all times. The version you seem to have... WOULD have a bellows like device that pushes on a plug lever... More complex... but I seriously believe both may be serviced through the OVERFLOW (will attach a drawing below)... OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE... Once you see the diagram of the drain MECHANISM... you will be able to see that jamming in a coat-hanger was a terrible idea. You can still most likely remove and repair the mechanism ... (from the over-flow) ELSE You are looking at buying a new one and installing the entire drain from the bottom (hopefully). Diagram of drains: Go to Bing homepage Carnac the Magnificent
3/24/2017 7:47:36 PM • Maax Plumbing • Answered on Mar 24, 2017
I just had a Maax Living tub installed but did not receive a manual. I searched the Maax website but could not find the answer I need: if I accidently push the drain, the water starts draining but I c
Good tips, but I haven't seen this answered yet. We just bought a house with a Maax tub. The drain is not a pop down, pop up deal. You push in a button in the overflow to raise the drain plug. But the vacuum of the drain pulls it down again. So you have to hold the plug in the entire time it takes to drain. I'm told something can be adjusted for this, but I'm not a plumber, and so far it's not obvious.
8/1/2015 10:03:03 PM • Maax Plumbing • Answered on Aug 01, 2015
Hi, i have a 40x60 base model 01225002. Could you tell me how much motar to put in place and any tricks you can give me on how to do it.
Use structo-lite. Its easier to work with and much lighter. You want enough to make contact with the bottom of tub.
10/28/2014 1:59:04 AM • Maax Plumbing • Answered on Oct 28, 2014
Shower bottom rollers
www.maax.com
8/20/2014 7:47:46 PM • Maax Plumbing • Answered on Aug 20, 2014
Shower installation instructions
look at the new frame to see how thick it is
6/7/2014 3:11:21 AM • Maax Plumbing • Answered on Jun 07, 2014
Heater is not working on a brand new maax whirpool
If it requires 110/220 volts and was wired to a double breaker... check to see that the do-it-yourself electrician put the breaker in a location that will give 220 volts and not 2 parallel feeds on the same side of the panel. Or else turn the double breaker off and then on to reset it.
10/15/2013 2:22:13 AM • Maax Plumbing • Answered on Oct 15, 2013
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
Maax Breeze: One Piece Round Shower Without Roof Cap but with MAAX IES 1/2 Logo
16 questions posted
Top Maax Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Maax Plumbing
  • Maax Plumbing
Most Popular Question
smell rotten eggs in shower drain
  • Plumbing
