20 Most Recent
Denon DBT-1713UD Questions & Answers
I have set my Denon DBT-1713UD (Controller RC 1161) to "Plarer 2". How can I resett it to "player 1? Or set it to Factory installation? How to?
When you set your main installation to player 2, you should also set the remote control to player 2. By that they match again.To do this, you press the "open/close" button and the "power" button both at the same time at the remote control for about 3 seconds. You will see the red led blinking twice. Then you press the button "2". The red led will blink twice again, after which the main installation and the remote control should both match as player 2.To change this setting on the remote control, you don't need to have an infra-red contact with the main installation.
Denon 687 ,,,,red light is on then I push the power button and it blinks green and their stays green but no display at all nothing else lights up
Considering you have a standby light we know the hot side of the power board is working, next step is test the power on signal coming from the main board, it should be marked on the legend on the power board what pin is power on, will be marked PO_ ON PWR or something like that, you need at least 3 vdc there when you turn the set on, if it's missing replace the main board, if you see voltage replace the power board, easy simple fix with only one measurement, verses guessing what board is bad. Sorry you didn't get any other useful help, there are some posters on here giving non helpful generic help anyone would know to try
Completely clueless on setting up Denon 1709 AVR
Yes, you can still use the speakers even if they are not currently connected to a TV. To connect the speakers to your computer, you will need an audio cable with 3.5mm plugs on both ends. One end will plug into the headphone jack on your computer, and the other end will plug into the input on the speakers. Some speakers may also have RCA input, in which case you will need an RCA-to-3.5mm audio cable.
If you have a newer computer with only a digital output (such as a USB-C port), you may need to use an audio interface or a digital-to-analog converter (DAC) to convert the digital signal to analog so you can plug it into your speakers.
Once the speakers are connected to your computer, you can adjust the volume using the volume controls on your computer or the speakers themselves. It's important to note that your TV will not be able to use the speakers unless they are connected to it.
How to fix my Denon DBP-4010ud Blu-Ray Player
Appears to be a software problem. Unfortunately, some blu-ray players contain software that expires, requiring you to repurchase newer, more expensive software from the manufacturer in order to continue to play blu-ray discs. Check your software for the player. No freeware blu-ray software out there.
How to unlock denon bluray dbt1713ud?
You can use a USB stick for region A, B or C. (1, 2 of 4)
On the USB stick there is one file named autoscript with the following : CLI(CLI_app.homemenu.set_bdreg 4). ,4 you can also use 1 or 2 this depends on the disired region.
Just copy this with textprogram and name the file 'autoscript'
T
1. Remove any discs from the drive of your player
2. Put the player into standby
3. Put the USB stick with the desired bluray region into the player
4. Turn on the player
5. Wait 5 seconds
6. Put the player into standby
7. Wait 10 seconds
8. Remove the USB stick
9. Unplug the mains cable
10. Unit should now be the region you have chosen for bluray
Before you do any firmware update, return to Region B as it may lock the region.hen do the following:
