20 Most Recent Stanley Lawn Mower. 54 in. 24 HP Kawasaki FR691V Heavy Duty Zero Turn Questions & Answers
WHY DOES OIL BLOW OUT DIPSTICK TUBE WHEN ITS RUNNING
Make sure it has the right amount of oil in the crank case, if over filled the oil will foam and flow out any place it can, Worn piston rings can cause blowby into the crank case , causing oil to escape from the dipstick tube.
2/8/2017 5:28:48 AM • Stanley Lawn... • Answered on Feb 08, 2017
Looking for replacement Stanley 61814 backpack sprayer parts. Replacement spray nozzle. Know where I can get them?
Chapin makes sprayers. They have parts. Just give model #. Phone 1-800-950-4458. Located in N Y STATE. Pump rebuild kit is $25.00 Inc shipping.
11/23/2020 9:13:20 PM • Stanley Garden • Answered on Nov 23, 2020
3answers
Stanley 10-801 utility knife. How
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
6/14/2019 1:15:31 AM • Stanley Garden • Answered on Jun 14, 2019
I have a Stanley model 425605x692b riding mower. runs very slow. runs fine otherwise. any way I can speed it up?
Is tranny and various speeds working properly? How about the throttle control? Do you have it set for higher speed?
8/25/2017 2:54:31 PM • Stanley Garden • Answered on Aug 25, 2017
Trouble shooting stanley 6.5 26 in cut. i cant pull cord to start. removed plug and when put back same problem
Try tilting the machine backwards for a few hours. It may be oil on the piston that is causing a vaccum
5/5/2017 7:01:19 AM • Stanley Garden • Answered on May 05, 2017
2answers
Need instructions for use of
4/10/2017 12:12:11 AM • Stanley Garden • Answered on Apr 10, 2017
Stanley P1800S pressure washer lost pressure after a few uses
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with. Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted on the wrong site on the hose , that it is used as water inlet on the tap.
12/25/2016 4:53:59 PM • Stanley Garden • Answered on Dec 25, 2016
Stanley carpet cutter model 10-525
This is a terrible tool took it apart to get the blade out of the handle and haven't been able to get it back together again.
7/24/2016 12:20:07 AM • Stanley Garden • Answered on Jul 24, 2016
I need an owner's manuel
Try manufacturer web site.
6/12/2016 9:07:17 PM • Stanley Garden • Answered on Jun 12, 2016
How do I get the top off? STUCK!
Hi Chris: It is usually easiest to rest the weight on the tailgate of a pickup truck (or some other device) and then slip out of the harness. Another technique is to lift bend forward while at the same time rising one shoulder and lowering the other. That will create "slack" on the low shoulder side allowing you to get that arm out. Cheers
3/19/2016 6:31:49 PM • Stanley Garden • Answered on Mar 19, 2016
Stanley Lawn Mower. 54 in. 24 HP Kawasaki FR691V Heavy Duty Zero Turn Logo
2 questions posted
Top Stanley Garden Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Stan Ford
Are you a Stanley Garden Expert? Answer questions, earn points and help others
View Most Popular
Stanley Garden
  • Stanley Garden
Most Popular Question
oil blow out dipstick tube when its
  • Garden
