20 Most Recent Delta Classic, Single Clear Knob Handle 4-Inch Centerset Lavatory Facuet wi Questions & Answers
If its a ceramic cartridge type then replacing cartridge is called for, HOWEVER sometimes cheaper to replace complete tap.
If not ceramic then turn mains off and replace the washer inside.
Delta Classic,... | Answered on Jan 08, 2010
https://www.deltafaucet.com/files/live/sites/delta/files/company/concierge/Touch_troubleshooting_guide.pdf
"Ifthesesolutionsarenotabletoresolvetheissue,pleasecontactourDeltaTech2O ConciergeTeamat1-844-923-5368
IFNOSOLUTIONABOVERESOLVESTHEISSUE,PUTFAUCETINMANUALMODEBYUNPLUGGING THEBATTERYBOXWHILETHEWATERISRUNNINGUNTILRESOLUTIONCANBEACHIEVED"
Delta Plumbing | Answered on Jun 09, 2019
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
Delta Plumbing | Answered on Jun 05, 2019
You need to install the screw that came with item, it goes under the handle thru the extension and into cartridge. Refer to instructions.page 3.
qk5krxajihraoapoi3zsan40ueqbvcpnowdvswq5rplcc5jjjt9xtd0q73fiheilr206ekaef1bbswnqkaf4ggaabui7kgbwcaadeaaaafvpkvylsawb+ibgaa+ig8cwcqbqibaaa6yjjomwucgc8qdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacr8f8dkgsefmplxo4aaaaasuvork5cyii=
https://media.deltafaucet.com/MandI/88723%20Rev%20B.pdf
seems like any dirt that gets in it may cut grooves in the disks and that is inly fixable by replacing them
Delta Plumbing | Answered on May 19, 2019
Open the battery case and realign the batteries with the positive and negative poles in the right positions according to the layout in the battery compartment. Close the battery compartment. Make sure it locks completely before continuing.
Locate the reset button, if any, on or near the battery compartment, after changing out batteries.
Push the red reset button to reset the faucet.
Test the faucet to ensure the reset corrected the problem.
Tip
Not all automatic faucets have red reset buttons. Some faucets just require inserting new batteries or realigning the batteries in the compartment to complete a reset. on the faucet. Check the instructions that came with your automatic faucet or locate the user's guide online at the manufacturer's website.
Delta Plumbing | Answered on May 08, 2019
There is normally a filter at the end of the faucet outlet. They usually unscrew. its usually a fine mesh screen with a plastic backing mount.
Delta Plumbing | Answered on Mar 22, 2019
rebuild it. buy a kit
Delta Plumbing | Answered on Jan 26, 2019
My recommendation is to reset the LED light wire and battery pack. To do this, disconnect the LED light wire from the solenoid. Disconnect the battery pack and wait a full minute. While you are waiting a full minute, you can check batteries to see if they are in good condition, even try new batteries. Make sure all batteries are in the correct direction and are tightly secured in the battery pack. After a full minute, reconnect the LED light wire into the solenoid and then reconnect the battery pack. Wait another full minute. After the full minute, you can then check your faucet and see if the lights work . If this procedure does not fix your issue, contact Delta Customer Service at (800)345-3358 Monday-Friday, 7am-7pm, CST and Saturday, 8am-5pm, CST. You may also email them at customerservice@deltafaucet.com.
Delta Plumbing | Answered on Dec 23, 2018
Just buy a new one, don't waste money and tine,
Delta Plumbing | Answered on Dec 08, 2018
The vacuum breaker could be defective.
Delta Plumbing | Answered on Sep 01, 2018
The diverter in the tub spout probably is clogged with mineral deposits, preventing complete diversion. Replacing the spout might help.
Delta Classic, Single Clear Knob Handle 4-Inch Centerset Lavatory Facuet wi Logo
1 questions posted
Top Delta Plumbing Experts
Thomas F. Schneider
Donni Steen
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Delta Plumbing
  • Delta Plumbing
Most Popular Question
delta single hanlde tub shower facuet
  • Plumbing
