20 Most Recent Tissot T-Race Mens Black Automatic Chronograph Sport Watch T0484272705701 Questions & Answers
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
4/9/2016 1:10:11 PM • Tissot T Watches • Answered on Apr 09, 2016
What is the reason my new Tissot watch is not working, which was bought in switzerland this year January?
If your watch is battery operated, the most common reason is battery itself. Don't mind it was bought in January, because watch itself could be in shop storage for years (even if it is one of the new models). If your watch is automatic/hand wound, then there might be a problem with movement and in this case you will need help of qualified watchmaker.
8/26/2014 3:42:06 PM • Tissot T Watches • Answered on Aug 26, 2014
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect? Did you put in the correct and a new battery? or perhaps you did put n the old battery? can you measure the voltage of the batteries, to check? Just a few questions that came up with me.
7/23/2014 11:58:46 AM • Tissot T Watches • Answered on Jul 23, 2014
Just got the battery replaced on my Tissot Supersport Chrono and now the chronograph buttons do not work. Any suggestions before I take it to a authorized repair shop?
Take it back to the shop that changed the battery. They have slightly misaligned the movement to the case. With a watch as good as a Tissot it is better to use a Tissot authorised dealer. My Seiko goes from Canada to London, UK for service.
10/26/2022 10:42:31 PM • Tissot Watches • Answered on Oct 26, 2022
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase there is a sunken button between the chronograph start/stop and the winding crown. Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
9/18/2021 6:20:20 AM • Tissot Watches • Answered on Sep 18, 2021
2answers
Hi, I have tissot expert, when I changed the battery, all option work perfect but the screen to activate compass not working and the bip as well,maybe battery not suit the watch ?
It could be that you have purchased the wrong battery for your watch and you should take it to a person that repairs watches and jewelry then to figure out what type of battery that will work in your watch.
3/8/2021 11:53:37 PM • Tissot Watches • Answered on Mar 08, 2021
How to zero the dials on Tissot 1853 watch
The reset button may be defective
11/16/2020 8:15:42 PM • Tissot Watches • Answered on Nov 16, 2020
My Tissot 1853 suddenly started to quickly run forward for 4 seconds and then rest for four seconds, doing that constantly. Is there a fix for this?
Hi. Can I assume this is a quartz powered watch? If so, sometimes, if thger bettery is either old or has started leaking hen is causes misfires in the time regulator.. First step would be chasnge battery & resdet the watch & monitor it. If this does not work, then put it into a Tissot service centre. Ifts not a quartz movement, there is no fault in a mechanical movement really that could cause this. Hope this helps.
10/6/2019 3:28:08 PM • Tissot Watches • Answered on Oct 06, 2019
Hi I have a Tissot Seastar 17 jewels manual wind 1964 mens watch. It runs, but is looses about 1/2 hr a day. Sometimes if i leave it face up on the table. It will run on time.
From your description it could be the main spring is broken, or there is a gear and or bushing failure. You will have to give the watch to a place that can service your watch. If you contact Tossot customer support they can advise you.
4/29/2019 8:07:01 PM • Tissot Watches • Answered on Apr 29, 2019
How to open the Tissot PR50 back to replace its battery?
A water resistant watch usually has a back that screws into the case and seals with a rubber O ring. Sometimes the back can be very tight to unscrew so even with the dedicated wrench it is difficult to remove without damage to the case. The professional would disconnect one end of the bracelet and clamp the case into a special holder. Once a non-dealer has replaced the battery it is usual to discover the back isn't replaced as tightly as original - this is reflected by the usual warning the watch will no longer be waterproof. The only way to retain the waterproof or water resistant quality is to have the battery replaced by a dealer or manufacturer when it will be, if required, pressure tested.
11/5/2018 2:06:46 AM • Tissot Watches • Answered on Nov 05, 2018
2answers
Tissot lelocle is loosing too many seconds a day and second hand jumps several times between second 10 and 25. Is there anything broken?
take it back for a warranty inspection / repair or refund maybe it is not genuine brand but a knock off in which case the manufacturer would like to be told about
6/16/2017 10:25:59 PM • Tissot Watches • Answered on Jun 16, 2017
Tissot T-Race Mens Black Automatic Chronograph Sport Watch T0484272705701 Logo
1 questions posted
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
tissot t race auto chrono watch stops
  • Watches
