20 Most Recent
Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg Questions & Answers
I need a 3v .255
best bet. enter item details in search box battery first then enter for the service manual . you may be lucky and get all you need on one web
What coused ASIC - error on my mac-1200 , and
if you can restart and access start window and settings. suggest you reset program with a previous saved update. could be a faulty update causing the problem. updates are a right pain in the posterior at times. save any work before starting an update that was working .
best suggestion i have , experience taught me with time wasting easier to reloadcpast window
My son is studying last year Bio Medical
I'm sure he has took standard repair procedures of eliminating "OPERATOR ERROR'. Now to get technical. In a hospital setting the fastest repair to a medical device is the 'Board Walk'. Use a working unit and CAREFULLY ( power unit down, GND yourself to both units, disconnect AC power, ect.) swap modules between units to isolate malfunction. In the old days we would check for possible bad component on the module. This can apply to the mechanic modules as well. I advise to look into Mgrs. for jobs.
Date 01/31/14
Does it keep losing the date when you turn it off? or are you asking how to set the time and date?
If you're losing time and date when you turn the unit off, there's a coin cell battery on the main processor board that needs replacing.
If you just want to set the time and date - Press "SHIFT" and 12 lead keys at the same time. select "7" for date and time, use the return key to select date or time
