20 Most Recent Tag Heuer Kirium Quartz WL111E.FT6000 Wrist Watch Questions & Answers
2answers
The hour hand on my tag chronograph does not stop
Try pulling out the crown to the first position. Then push upper and lower button simultaneously. The red stick will start moving 1 second per push. Repeat procedure until it reaches zero position, then push back the crown to the normal position.
5/12/2016 8:39:04 PM • Tag Heuer Kirium... • Answered on May 12, 2016
3answers
I have just purchased a
hi there,
Is it way off the 12 hour marker? if it's just a bit off the 12 time then I suggest you let it go because the second hand marker does not have an adjustment lever outside the wristwatch but you would have to open the back of the clock and adjust the gear of the second hand inside.
If you are comfortable enough you can try to open the back of the watch and look for the constantly moving gear inside and make the necessary adjustments.
If you'd still want to have it fixed but don't want to open watch yourself then you'd have to take it to a local watch repair man or to a watch repair shop and they can do the job for you.
Hope this helps!
6/30/2011 3:26:55 AM • Tag Heuer Kirium... • Answered on Jun 30, 2011
Tag Heuer Women 934.208 works fine but couldn't adjust date or time
send in for repair to a watchsmith
1/22/2022 1:06:18 PM • Tag Heuer... • Answered on Jan 22, 2022
2answers
What kind of watch winder do I need for this watch
You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction). AUTO-WIND function is NOT at all unique to your watch... After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly) MTE watch winder (their very basic WTS-4). Good luck: I WILL try to include the URL (see page 6) http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
7/30/2020 12:51:36 AM • Tag Heuer... • Answered on Jul 30, 2020
I have a tag Heuer kirium model cl111a how do you adjust the time on it
Contact manufacturer they will help. :-)
7/17/2019 1:18:31 AM • Tag Heuer... • Answered on Jul 17, 2019
I have a kirium model cl111a how do you adjust the time please ?
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch.
7/2/2019 6:12:56 PM • Tag Heuer... • Answered on Jul 02, 2019
TAG Heuer stopped working - does any one know where I to download a manual from and get troubleshooting advice as well? Thanks, Colin
why not just take to a watch/jewellery store and get battery changed
1/21/2019 10:46:27 PM • Tag Heuer... • Answered on Jan 21, 2019
Is my Tag Heuer real. Waf1415. Ck2251 it's a diamond dial Aquaracer. Women
Tags once were often on the fake market but this watch should be real. A watch repair shop can open the case and tell you quickly. Its about a $1500 watch new.
10/7/2018 10:42:32 PM • Tag Heuer... • Answered on Oct 07, 2018
How to set time on TAG HEUER SLR Chronograph?
Thank You for Article :) http://www.khasbox.com/
7/28/2018 6:22:22 AM • Tag Heuer... • Answered on Jul 28, 2018
Tag Heuer Watch secconds stop what to do?? then i push a button fixed above the screw - secconds keep starting, but after few rounds, its again stopped at 12. plz advise how to fix this problem??
this game, you start at the cavern men's age, then evolve.The goal of the game also differs depending on the level. In most levels the goal is to reach a finish line or to collect tokens. Many levels feature alternate or nonexistent goals for the player. The game controls are shown just under animaljam 2 ' five nights at freddy's 2' hotmail login
5/6/2017 4:25:02 AM • Tag Heuer... • Answered on May 06, 2017
Tag Heuer Kirium Quartz WL111E.FT6000 Wrist Watch Logo
2 questions posted
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
View Most Popular
Tag Heuer Watches
  • Tag Heuer Watches
Most Popular Question
just purchased
  • Watches
