Your fridge might have a battery packed attached to it. This would be one thing that could cause your fridge lights to still function even without being plugged into an outlet. Thank you.
In most cases the thermostat is not operating as it should. First see if the probe is still in its clip on the fins of the evaporator ( the thing in the back ) if it is still in position the thermostat is most likely bad.
Hi I have found your details on the internet but noticed we are a good distance away I have a elddis crusader tempest and 2010 with a thetford fridge freezer N175 fitted and seen they are 1200pound new on Saturday my freezer defrosted by itself and fridge isn't as cold as it should be and I've got no error codes or spanners on it they is heat coming out the vents and blue light stays on and doesn't flash I'm sited all year around its been working fine but I have left it on for a couple months with out turning off it's connected to EHU And it runs on gas as I can hear it run on it but didn't keep ice cubes froze hope you could help us out thanks PLZ HELP
