20 Most Recent
Magic Chef MCBR360HW 3.6 cu. ft. Compact Refrigerator With Glass Questions & Answers
1979 magic chef 14.6 cu refrigerator not cooling
There are a number of reasons a refrigerator does not cool. Make sure that the condenser fins are clean. Is the passage from the freezer side blocked not letting the cold air enter? Has the thermostat been turned down? May be low on freon. This site may help you.
https://www.familyhandyman.com/project/how-to-repair-a-refrigerator/
Magic Chef mcbr415s compressor is hot and its not cooling
It sounds like your Magic Chef refrigerator is experiencing a cooling issue. The fact that the compressor is running constantly and getting hot suggests that it is working overtime to try and cool the fridge, but it's not able to achieve the desired temperature.
First, check to see if the temperature controls are set correctly. If they are set too high, this can cause the compressor to run constantly. Additionally, make sure the fridge is not overfilled, as this can restrict air flow and prevent proper cooling.
If those checks don't resolve the issue, it's possible that the power outage may have caused damage to the compressor or other components. In this case, you may need to have a professional technician take a look at the fridge to diagnose and repair the problem.
Unfortunately, if you are unable to access the condenser coils, it may be difficult to troubleshoot the issue yourself. You may need to contact a technician for assistance
Magic chef ice maker seems to do everything but freeze the water
After cleaning out the machine, please double check that it's not attempting to cool any object that's extremely hot. Also, you might want to switch power outlets and test the cooling again. Then if still not working, you can use the troubleshooting section of the manual to help overcome the issue. Thank you.
