20 Most Recent
MAG Simmons 22 Mag Rifle Scope 511039 Matte 3-9x32 W/rings Questions & Answers
I bought a Simmons model
You can set it in the rings so that it is correct. However the thing that you need to know is that the screws push on a tube in the scope so, if the side screw is turned you are adjusting windage becaues you are pushing the ube side to side. If the top tube is turned you are adjusting elevation becasue the tube is moving up and down. Another thing that you need to know is that there are springs on the side of the tubes OPPOSITE from the screws. So when you turn the screw it holds the tube tight against it.
