20 Most Recent Whirlpool Duet WFW9050XW Washer Questions & Answers
My wfw9050xw stoped in the middle of a wash. It wont spin, drain,wash or do anything. when I unplug it and plug it back in, I can press the control button ang og to drain , but it spins about 3/4 turn
Anonymous: Thank you for your review. We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We look forward to your reply. Thank you, Whirlpool® Social Media Relations
3/9/2018 5:11:46 PM • Whirlpool Duet... • Answered on Mar 09, 2018
Washer will not start
Havenison you tried pushing the door in case it isn't connecting .
12/26/2012 9:54:07 PM • Whirlpool Duet... • Answered on Dec 26, 2012
Whirlpool Duet Washer. The hot water just runs into my washer when I turn it on. What should I do?
That is what is supposed to happen. You turn it on to a program, the water comes in and it washes the clothes. I think we must be missing some information? Some wild guesses in this link https://www.google.com/search?q=Whirlpool+Duet+Washer.+The+hot+water+just+runs+into+my+washer+when+I+turn+it+on ..
5/13/2023 3:16:37 AM • Whirlpool duet... • Answered on May 13, 2023
2answers
Code F05 -E02
According to the manufacturer, the error means the door could not lock. Check the door for obstructions when you close. To remove error, reboot the washer.
9/1/2022 12:04:22 PM • Whirlpool duet... • Answered on Sep 01, 2022
Whirlpool Duet F08 E03 in Diagnostic Test Mode and stuck in C00 during diagnostic
google reset of motor or see if schematic inside case
3/5/2022 4:11:14 PM • Whirlpool duet... • Answered on Mar 05, 2022
Where is the Filter on Whirlpool Duet Front Load ?
Moved to Whirlpool Washing Machines Category. I see you met our Computer Guru Larry :>D He hates his when his department gets cluttered with non-computer posts. Details on cleaning the filter in the link. https://www.google.com/search?q=wfw9550wl00+clean+filter ..
7/29/2021 4:50:23 PM • Whirlpool duet... • Answered on Jul 29, 2021
The cycle stopped with 2 minutes left. It stopped spinning and had an inch or so of standing water. It was making a clicking sound. I hit the pause button and it would not cut off. I unplugged it and
as far as the standing water, try to reach the water pump to remove the button or other things that dropped out of you trouser pockets stopping it from emptying properly, as there is still water in the tub the machine wont move on till its empty eric
1/20/2018 9:05:13 PM • Whirlpool duet... • Answered on Jan 20, 2018
Whirlpool washer model wfw9050xw00 This unit is 1 yr old and is stopping at various times during all of the cycles. Also the unit is buzzing a bit when it is using the pump for drainage. Some times
Only 1 yr old so I assume its a simple fault like partial blockage at pump. Remove filter bottom right of machine check and clean if needed . remember to use an old towel fist as this will contain around half pint of water assuming its drained 1stly , Always unplug machine from Electrics before any repairs, Good luck.
1/8/2018 4:07:06 PM • Whirlpool duet... • Answered on Jan 08, 2018
Whirlpool MFW9700SQ1 FH problem
there's a flow meter in the washer that could cause this part number WPW10110225 if you go here you can see it https://www.repairclinic.com/PartDetail/Flowmeter/WPW10110225/1381535 also check the screens on the water valve,it's telling you the machine thinks it's not filling with water or it isn't filling,also this could be a bad pressure switch or the computer board but if you order parts from repair clinic you can return them and you have 365 days to do this,so first thing check the screens on the water valve,shut down the water and remove the fill hose from the washer and see if there's any junk in the screen,if so you can clean off the screen and see what happens or replace the water valve,if that looks ok the flow meter is probably gonna be it so this might be the part you want to change out,i can't remember how to test the flow meter,i carry one so if i see this error i pop it on and see what happens and out of the three times i've seen this it was the flow meter.hope this helps you can google how to check it the instructions on the tech sheet in your washer isn't that good but you can check it out.good luck with your washer
12/30/2017 1:20:42 AM • Whirlpool duet... • Answered on Dec 30, 2017
2answers
F1e1 error codes
Check the harness from the ccu .If all in tacked replaced the ccu.
11/16/2017 1:18:45 AM • Whirlpool duet... • Answered on Nov 16, 2017
When I hold start button, longer beeping noise won't start
might be your lid lock are door lock switch is bad if you have your manual tell how to put washer in program mode then it should give you a errcode show you what wrong with your washer ok
10/21/2017 5:04:03 PM • Whirlpool duet... • Answered on Oct 21, 2017
Whirlpool duet WFW9600TA00 f35 error
F35 error code is indicating a problem with the water level pressure switch operation (key#20). There could be a blockage in the air dome or pressure switch hose (key#21). The air dome is located on the back of the tub on the left hand side SUD means the washer has detected suds, or foam inside the basket. Suds will cause the washer to wash poorly, and it can lead to other issues. The first step is to confirm you are using H-E detergent. H-E detergent is formulated to get your clothes clean with less water, and without creating foam F25 is a DRIVE MOTOR TACHOMETER ERROR. This error is one of the toughest one since it really does not narrow it down. I would do plenty of testing before replacing the expensive parts. If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 Minutes. Possible Causes/Procedure 1. Verify the shipping system including shipping bolts, spacers and the power cord are removed. 2. Unplug washer or disconnect power. 3. Check drive motor tachometer resistance. It should be approx. 115 ohms. 4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). 5. Plug in washer or reconnect power. 6. Check the MCU by looking for operations of the drive motor. 7. Check the drive motor for powered rotations. If everything checks out okay, you should think about replacing the MCU since it may not read your motor correctly.
9/10/2017 3:26:18 PM • Whirlpool duet... • Answered on Sep 10, 2017
Washer doesn't want to spin out into the high gear spin on the quick wash cycle
Consult Warranty from manual. Probably needs a new controller.
9/1/2017 10:38:00 PM • Whirlpool duet... • Answered on Sep 01, 2017
Whirlpool Duet WFW9050XW Washer Logo
7 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
duet Whirlpool
  • duet Whirlpool
Most Popular Question
wfw9050xw stoped in middle wash wont
  • Washing Machines
