20 Most Recent Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle Questions & Answers
2answers
Tasco 6x24x42 cosistancey issues afield.
It has to settle in to the mounts an the mounts to the gun. You take a screw driver and tap on the scope as you adjust it. Tap with the handle and just tap it not bang. every time you make an adjustment tap it. The 222 does not give a great kick so you do not get the settling from that, you have to cause it by taping the scope with the screw driver.
6/7/2015 11:17:43 AM • Tasco... • Answered on Jun 07, 2015
What are adjustments on front of scope
For parallax error correction at different distances
3/25/2015 4:39:00 AM • Tasco... • Answered on Mar 25, 2015
3answers
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
10/5/2014 7:21:02 PM • Tasco... • Answered on Oct 05, 2014
2answers
Do i have to loosen
Sight in your scope, Loosen the set screws and zero the dials the re-set the set screws. This will make it easy for you to adjust for distance and wind from the zero setting when in the field shooting. Then you can go back to your zero.
4/25/2014 12:18:08 AM • Tasco... • Answered on Apr 25, 2014
3answers
When you zoom your scope does the impact point
No, the cross hairs remain fixed. The zoom serves only to magnify the field of view.
Aduz
11/29/2013 5:09:14 PM • Tasco... • Answered on Nov 29, 2013
When I turn the turrets they go in the reverse
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
6/11/2011 4:06:26 PM • Tasco... • Answered on Jun 11, 2011
Need to know what power that mil-ing targets needs
According to the manual VAR624X42M is calibrated at 8x.
2/16/2011 7:20:24 PM • Tasco... • Answered on Feb 16, 2011
My cross hairs do not
This happens a lot during bore sighting, - no shock to the scope to jar the cross hairs. So take your screwdriver and use the handle - rap the scope or better just tap it. Not hard enough to bend/dent it but jar it so things can move if need to.
1/10/2011 12:30:20 PM • Tasco... • Answered on Jan 10, 2011
Have a Tasco 6-24X40MM BDC scope and need the
I have the chart for the TR624X40MM BDC rifle scope. Send me an e-mail to [email protected] with your e-mail address or fax number and I can send you a copy.
12/10/2010 10:26:43 PM • Tasco... • Answered on Dec 10, 2010
Once zeroed in is the range on the turrets correct
This depends entirely on what class of cartridges the scope was built for. Different cartridges will drop more or less at a specified distances based on starting speed and ballistic coefficient. If your scope is built for a .223 and you are shooting a .223, then it will work fine. If you mounted it on a 45-70 however, the bullet will drop much more quickly and your necessary scope adjustments will not match the markings on your scope.
10/14/2010 1:23:03 AM • Tasco... • Answered on Oct 14, 2010
Cross hairs wont move when
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
9/22/2010 6:02:56 AM • Tasco... • Answered on Sep 22, 2010
Elevation turret stripped out. Entire turrent
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
9/6/2010 7:37:30 PM • Tasco... • Answered on Sep 06, 2010
Moa not true past 300yds tasco 6x24x42mm
The Tasco is not a 600 yrd scope by any means. If you want to get rid of them, there are plenty of deer hunters who will use it at 100 yards and never go beyond that. The MOA is usually imprinted on the windage dial, it will have a little fraction or a decimal there telling what it is at 100 yards. There are a couple good scopes out there, Nikon and Pentax are decent. Leupold is about the best. It will deliver beyond your eye vision and rifles potential. I have a Bushnell on my M-40, mainly because I can't afford a $1000 scope, but I can shoot door knobs off at 200 yards all day. The scope is a piece of junk, but I have it set up right and it works, Hope this helps.
4/27/2010 2:01:50 AM • Tasco... • Answered on Apr 27, 2010
Crosshairs look like an x instead of a cross
You can get to the cross hairs of a scope, but not much further without some special tools. Take off the rear lens, just unscrew the whole thing, and you will see inside there a ring with slots in the side? A small screwdriver in one of the slots should spin the threads out. You should be able to remove the cross hair tube, inside of it on the front, you should have another lock ring with the slots, spin the cross hairs straight and lock them down. This is a basic scope, I'm sure they are all different, but basically the same. Try it. You cant hurt it, it's already broken, and you will have to send it back out again if you fail. I don't know what they charged you, but there is a guy on ebay advertising scope repair, $45, all scopes.Hope this helps.
4/19/2010 1:32:34 AM • Tasco... • Answered on Apr 19, 2010
On the adjustment turrets, after loosening the set
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
4/5/2010 4:40:55 PM • Tasco... • Answered on Apr 05, 2010
Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle Logo
Popular Tags
34 questions posted
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
View Most Popular
Tasco Optics
  • Tasco Optics
Most Popular Question
loosen
  • Optics
