20 Most Recent
Whirlpool 24" Double Electric Built-In Wall Oven Questions & Answers
Whirlpool double wall oven RBD275 won't hold temperature
Try this: Check your thermal coupler, it should be reading approximately 1080 ohms of resistance at room temperature. If your connection is bad or the coupler is bad this could quickly cause a temperature issue. However if you have replaced this component and still have the same issue it's likely your ERC is bad. You can have this repaired for $99.99 through The Repair Shack. Your control board part is 8301917 which is no longer made. Here is a link to have this part repaired
Repair Service For Whirlpool Oven Range Control Board 8301917.
If you would rather replace the board you can use substitute part number W10438751. The cost from
The Repair Shack is $325 with free shipping. You may be able to find cheaper elsewhere but we have the part available.
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Whirlpool YWFE710H0BS0 oven no longer heats up.
Check the elements for continuity with a multimeter. Sometimes the connectors draw too much current and can burn out as well. Both are easy tests. A runaway temperature can make elements fail because there is no thermostatic control, they just glow bright yellow..
What does E1 F2 code means?
Greetings,
This might indicate a bad keypad or that the cable connecting the keypad to the chip board within your whirlpool has come loose. You might need to work with whirlpool to see if they keypad needs replacing or if the internal chip board itself is faulty.
Thank you.
I Have a whirlpool gold accurate system microwave /oven combo
Self cleaning and broiler is not working . Regular oven works . There are no error messages . What is causing this
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
How to set the clock to not display time
the time?
You can turn off the clock display from the oven's control panel. Look for a setting that says "Clock" or "Time of Day" and set it to OFF. If you don't have this option on your oven, contact the manufacturer directly and they will be able to help you.
