20 Most Recent
Tag Heuer 2000 Classic WK1311 wristwatch Questions & Answers
New battery required
Any Tag Heuer dealer should be able to change your battery for you. Just go to Tag Heuer's website for a store locator. Or, just go to a search engine and type in "Authorized Tag Heuer Dealer *location*, *location*" whereas location is where you live. You will get a list of stores near you. Call them first to make sure they can do it and you're set.
Good Luck.
Womens tag aquaracer wk 1320- have had it for over
An 'overhaul' as we say in watchmaking refers to completely disassembling your watch, repairing or replacing parts as necessary, cleaning the movement in a machine designed for cleaning watches, reassembly, regulating the timekeeping to the best of the watches ability, polishing or cleaning the case and band and possibly replacing the crystal if necessary. It varies slightly from brand, watchmaker, quartz or mechanical, pocket or wrist but generally this is what an overhaul refers to. It is a complete refurbishment of your watch.
I cannot pull out the
The time setting screw is more accurately called the crown which is, in your case, a 'screw down crown'. This is done for water resistance. You must first unscrew the crown before you can pull it out. When you are finished setting the watch you must screw it back in. It may require that you press in on the crown and turn it at the same time to get the threads to catch. No need to overtighten it.
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
