20 Most Recent
Praktica Dpix 3000 Digital Camera Questions & Answers
How to format a card
If you are using SD Card then simply insert into a card reader, double click on the disk when shown in My Computer (may say Removable Disk). You can press Control then A to select all files on the card, press delete.ORYou can right-click on the removable disk from the 'My Computer' screen then select FORMAT
Hello, we just came from
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I want to install a
You probably mean Picasa ( http://picasa.google.com ).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Did not get a disc with my dpix 5200 camera im unable to send pic
Prakticam, unhelpfully don't have anything for their cameras more than a couple of years old and don't seem to care if you mislay the disc you paid for.So be warned, don't buy Praktica. I have the 5200, you have firstly to put your usb in computer, switch on camera, switch camera to view pictures taken mode, and because it auto switches to take picture mode you then carefully attach camera end into camera whilst camera is still switched on! Then go to my computer and click on F: the pictures download. Then to save them click on first pic, hold shift key down and then click on last pic they should all highlight, right click and then hover 'send to' and send by left clicking to my documents. I remember that it took me 4 hours to work it out. Found this looking for manual to download, cannot change date now......
PRAKTICA DPIX5201G
First switch on camera then attach usb cable.
Computer sees it as a memory device.
Its a praktica z212
Is it really - how fascinating. Now please can you tell us the significance and relevance of this somewhat terse comment ?
