20 Most Recent Leupold ® Rifleman® 3-9x50 mm Scope Questions & Answers
Double lines
the scope needs to be fixed by leupold or replaced.
10/13/2013 6:21:49 AM • Leupold ®... • Answered on Oct 13, 2013
This is my first Leupold scope, I don't understand
minute of angle is not the same as 1/4" per click at 100 yards. if it doesn't click something is wrong. i would call leupold and probably try to get a replacement from where you bought it. moa is an angle value not an inch value.
10/13/2013 6:19:52 AM • Leupold ®... • Answered on Oct 13, 2013
The magnification adjustment dial on my Leupold
i would send it to leupold and have them check it out.
10/13/2013 6:12:05 AM • Leupold ®... • Answered on Oct 13, 2013
Leupold VX II 3x9x50mm scope on a rem. 270. One
16 clicks is about 4" at 100 yards not 25. did you try shooting it at 100 yards? remember the scope is mounted at least an inch and probably higher than that above the barrel. at close range you will always hit low with a scope because the bullet has to climb at least an inch or more before it will be right on at 25 yards. if it is dead on at 25 it should hit way high at 100. (or the scope/ mounts are bad).
10/13/2013 5:49:40 AM • Leupold ®... • Answered on Oct 13, 2013
Leupold 3x9x40 vari-xIIc on BAR30-06. Adjusted windage as far to the right as possible and I'm still 6-8 inches off center. 12 year old scope been dead on till the middle of this season.
from my experience owning a bar they tend to lose accuracy badly after a lot of rounds are put through them especially if they are shot rapid fire style allot ( the barrel gets very hot and i am also not impressed with how the barrel is attached to the receiver) i shot mine until it just would not shoot accurately at all. (i sold it). its possible that your scope or mounts are loose defective or there may be a screw that may be broken under the mounts that you cant see.
10/13/2013 5:13:13 AM • Leupold ®... • Answered on Oct 13, 2013
What directions do you turn
Here is a diagram showing all the settings: wswift_5.jpg
5/17/2011 10:37:36 PM • Leupold ®... • Answered on May 17, 2011
I have about a 1989 model Leupold 3x9 Var X and
You have a number or a fraction on the inside of the windage cap, or you should, it will say something like 1/4 or 1/2? That will tell you how many fractions your scope moves with each click, at 100 yards. Anyway, there is also a left and right direction on the scope, you want your scope to go in the direction of your bullet miss, this will pull the barrel over to the center, again, it is supposed to. If you have run out of clicks, you will need to shim your scope. So, on the 1/4 inch at 100 yards, you will want to move the dial, 8 to 12 clicks to the right. Shoot it again, if it went the wrong way, you know what to do. If it didn't move at all, try this.... If it is a bolt action rifle, pull the bolt out, mount the rifle in a cardboard box with v grooves cut in it so it will cradle and not move, or a vise, sight down the barrel at a target at 100 yards, then peek down the scope, it should be right on the target, if not move the cross hairs till it aligns, check the barrel again, make sure it didn't move, then peek through the scope again, if it is the same, it will be on paper at 100 yards, if it is not a bolt action, the only other rifle you can d it with is an AR type rifle. This is a military trick, not something I dreamed up, it works. Check it out.
11/11/2010 2:48:24 AM • Leupold ®... • Answered on Nov 11, 2010
I had my 6.8SPC dead on at 100....I went and shot
You have to check inside the right cap for the MOA, if it is 1/4 MOA, it will not adjust 56 inches. You will need to shim the bases to get it up there and then you have a small window up and down. But, check the ballistic table for that bullet and then determine where the best zero will be, Like maybe 300 yards, then it only has a few inches to go to get 600, and a few inches down for 100. I am not familiar at all with the 6.8, I mess with military ammo only. But I don know what bullets do. Hope this helps.
7/24/2010 6:49:02 PM • Leupold ®... • Answered on Jul 24, 2010
Hi, i was thinking of getting a leupold
The 4-12 X 40 means 4 time magnification to 12 times magnification with a 40 mm objective lens.
This indicates that you can zoom from 4-12 times the unmagnified size of your subject.
Short answer - Yes!
6/3/2010 2:47:21 AM • Leupold ®... • Answered on Jun 03, 2010
Will not work after dusk.Does NOT enhance any
I think you are a little mixed up with what a low light scope actually is.
If you look through a standard scope and a low light scope at dusk and compare the image, you should see a little clearer with the low light scope.
These are designed to allow you 10-15 minutes extra shooting time over a standard scope in low light conditions.
If you want to be sneaking round in the dark like snake from splinter cell, i'm afraid you have the wrong bit of kit.
You will need a Night Vision scope which use infra red and an image intensifier to amplify the light and convert it into an image that the human eye can see.
RobbieP
BSA Owners Group
11/23/2009 1:44:42 PM • Leupold ®... • Answered on Nov 23, 2009
I have a bushnell scope on my muzzle loader and it
the top knob should have up or U with an arrow on it showing which direction to turn it
11/1/2009 4:52:25 AM • Leupold ®... • Answered on Nov 01, 2009
Rifle scope will not track with the adjustments
When you make your adjustment tap on the scope with a small screw driver handle a few times before you fire her. Work slow and tap as you go.
6/28/2009 11:55:37 PM • Leupold ®... • Answered on Jun 28, 2009
Overtighten causes hazing,and adjusment problem
As a general rule of thumb, If you have normal Weaver-type aluminum rings, you tighten to 10 to 15 inch-pounds. If you have normal Weaver-type steel scope rings, you tighten to 15 to 20 inch-pounds. If it's something exotic and/or expensive, you're pretty much stuck contacting the manufacturer. Leupold Mark 4's require 65 in-lb, for instance.
Wiha makes two adjustable torque screwdrivers (one for lower torque, and one for up to 60 in-lb that are perfect for most any scope ring applications.
5/14/2009 1:13:30 PM • Leupold ®... • Answered on May 14, 2009
Remounting a rifle scope, Luepold 3X9 with Luepold rings
hey jerry when ya renount a scope ya just want to tighten all the screws evenly when ya do this ya want to start with right front then left rear then left front right rear you do this till its as tight as you can make them without striping screws when your done you should have even space at all the rings good luck and i hope this helped ya
3/2/2009 3:12:01 AM • Leupold ®... • Answered on Mar 02, 2009
My Leupold RX 1200i - TBR DNA does not compute True Ballistic Range in Rifle mode only in Bow Mode. Am I doing something wrong?
Contact Leupold Support direct. We are Fixya, we aren't they and we can't give feedback on an issue like this unfortunately. https://www.leupold.com/shop/rangefinders/series/rx It may be a laser issue and needs calibration or repair. https://www.bhphotovideo.com/c/product/1059069-REG/leupold_119360_rx_1200i_tbr_with_dna.html .. ..
10/30/2021 12:49:08 AM • Leupold Optics • Answered on Oct 30, 2021
Leupold Rx750 will only show partial numbers when trying to get yardage
Make sure all the batteries are good
3/13/2019 10:38:14 PM • Leupold Optics • Answered on Mar 13, 2019
Leupold ® Rifleman® 3-9x50 mm Scope Logo
17 questions posted
Top Leupold Optics Experts
john h
Kardoc
Are you a Leupold Optic Expert? Answer questions, earn points and help others
View Most Popular
Leupold Optics
  • Leupold Optics
Most Popular Question
6 8spc dead 100 went shot
  • Optics
