20 Most Recent Canon EOS 5000 35mm Film Camera Questions & Answers
The photos from my EOS 5000 film camera have two
Difficult understanding what is going on. If it is in the print then look at the negatives. Are they on there, if so check with your lab it may be a processing machine issue.
11/28/2016 3:52:56 AM • Canon EOS 5000... • Answered on Nov 28, 2016
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
4/7/2012 4:02:09 AM • Canon EOS 5000... • Answered on Apr 07, 2012
I was given a Canon
You can download the manual from
http://butkus.org/chinon/canon/canon_eos_5000/canon_eos_5000.htm
It's free, but the webmaster requests a donation if you find the manual useful.
5/10/2011 11:35:32 PM • Canon EOS 5000... • Answered on May 10, 2011
I'm getting an ERROR 99
see to it there's no jam on parts mechanism inside, it need to reset to authorized service center or find reset button on the unit but not all slr have it outside some are located inside some dont have it
2/12/2011 11:22:38 AM • Canon EOS 5000... • Answered on Feb 12, 2011
What setting do I use
This site has the entire manual which explains how to use your camera:
http://www.butkus.org/chinon/canon/canon_eos_5000/canon_eos_5000.htm
12/1/2010 10:01:21 AM • Canon EOS 5000... • Answered on Dec 01, 2010
HOw much i can sell on ebay ?
Go onto eBay, do a search on this camera model, and select "completed auctions only" in the filter panel on the left. You will then see auctions that have ended and what the final price was.
10/27/2010 6:48:38 PM • Canon EOS 5000... • Answered on Oct 27, 2010
Can you use a memory
No. The EOS 5000 is designed to use 35mm film. Unless you have a complete electronics fabrication facility and machine shop, there is no way to convert the film camera to digital. At one time Kodak did convert some Canon and Nikon cameras from film to digital, but those cameras cost $15000 or so and were only about 1 or 2 megapixels.
8/23/2010 8:28:51 PM • Canon EOS 5000... • Answered on Aug 23, 2010
After develop the pictures i found that some
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
10/8/2009 8:44:49 PM • Canon EOS 5000... • Answered on Oct 08, 2009
I can't get my EOS 5000 camera to load the film.
In frustration I took the bottom off the camera, fiddled about with the cogs, reassembled and it worked! No idea what I did but the result was a good one.
davidyarwood
3/19/2009 9:27:35 AM • Canon EOS 5000... • Answered on Mar 19, 2009
2answers
Canon AE-1 Program needs cleaned or am I missing a step?
Hello
Thank you for using FixYa for your problem
I am guessing it may of been lying around for a while, some of the parts have stopped moving right, a good strip and service will solve it. There was a manual to service these years back or take to a service agent
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
12/1/2018 5:44:46 PM • Canon... • Answered on Dec 01, 2018
tip
Saving Money On an External Flash for your DSLR
Save money (lots) by NOT buying a name brand smart flash for your camera. Bottom line - Expert photographers use manual settings on their cameras and their strobes to take photos. It is the newbies, occasional shooters who need the auto settings (see exceptions) - and the auto settings that cost so much on the external flash units for Canon and Nikon Cameras. A "smart" flash from Nikon could cost more than $600 while a "not smart" third party flash should cost $40 or less. "not smart" means that you tell it how powerful it should be when the shutter is released - and then it gives you the light you set when you click. A "smart" flash takes into account the surrounding light and the aperture set in the camera in order to determine the power of the flash delivered when the shutter is clicked. "Smart" flashes also have a manual mode. Why do you need an external strobe unit? Don't you already have a flash built into the body of the dslr?? First - the strobe built into your camera is pretty weak. Second, it is immobile. Third, it is only a single point of light. With a dedicated power source (generally AA batteries) an external strobe has more power. The strobe head can be rotated and pointed in almost any direction. By being removed from the lens about 4 inches, it is often enough to eliminate red eye in photos of people. And, by being movable, the photographer is able to control shadowing on the subject. A further benefit is most of these strobes come with a 'built in slave', meaning that the light from one flash unit can trigger the flash of another flash unit. That means that for less than 25% of the price of a "smart" unit, you can afford 3 or 4 of the "not smart" units and control them with your built in flash. This gives the photographer a great deal of creative flexibility and the ability to light up an area far away from the camera - wirelessly. for more on the use of an off camera flash, search strobist with your search engine. exceptions - there are certain situations where the brain of the flash computer is really helpful to adapt to quickly changing lighting situations and from a practical standpoint, manual settings may not be able to keep up with the changes without missing the shot. An example is weddings where the venue moves from well lit to poorly lit places or in and outdoors, or in and out of shadow situations. But, most shots are taken in a venue where lighting doesn't change and hundreds of shots are taken in virtually the same setups, same distances, etc. Here the camera can (and probably should) be set to manual settings and the flash also set to manual power. In fact, by using automatic settings, there are many processes that have to work perfectly in order for the proper exposure to be taken. These processes take computing power and an instant of time - which, depending on the computing power of your camera, could cost you that shot. But, if you are taking wedding photos and faced with varied lighting situations, hopefully you can afford good lighting tools.
on Feb 25, 2018 • Photography
My canon A1 shutter fires at all speeds, mirror
Your shutter leavers are getting slow. They will fail soon, most likely the old grease is sticking. You can get a replacement body for $40 as repairs/cleaning will be $80+
2/20/2018 5:41:42 PM • Canon... • Answered on Feb 20, 2018
My camera got slightly splashed with water, I
It is unusable because it is 'broken'. You've not specified the make and model, but if it was a cheap one (under £500) just replace it.
12/10/2017 9:54:04 PM • Canon... • Answered on Dec 10, 2017
I have a Canon Rebel
I'd check with Canon. They will probably want you to send it back . . . be sure the price of the repair is going to be considerably less than a new (refurbished) camera.
11/2/2017 3:50:35 PM • Canon... • Answered on Nov 02, 2017
Low battery indicator, even after a new battery
You probably have a dead cell in your replacement battery. Camera batteries have a limited number of charge cycles, and this is not a rare issue with "aged" batteries. Also, when you get a new battery, buy a genuine Canon replacement and not one of the el-cheapo Chinese copies available online. In camera batteries, you really do get the quality and performance you pay for!
10/6/2017 1:59:06 AM • Canon... • Answered on Oct 06, 2017
Need replacement plate for fitting Canon camera to 5800D tripod
As it is a Sunpak tripod, contact the mfr or importer, or look on eBay. Fixya does not supply spares for any equipment.
10/4/2017 9:48:11 PM • Canon... • Answered on Oct 04, 2017
I am using a Canon A1, and the film advance lever is stuck and the meter does not show. It was just working a minute ago.
Rewind the film and try 'dry-firing' the camera, checking to see if the lens is working properly. May be a bad contact between the lens and the body, may just the the film has loaded slightly on the huh.
10/2/2017 8:33:07 AM • Canon... • Answered on Oct 02, 2017
2answers
Changing shutter speed for 35mm Canon E0S Rebel camera
You should download a manual. Specs say it is an autofocus and autoexposure camera with limited manual input required.
9/12/2017 1:17:41 AM • Canon... • Answered on Sep 12, 2017
Canon EOS 5000 35mm Film Camera Logo
Popular Tags
11 questions posted
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
View Most Popular
Canon Photography
  • Canon Photography
Most Popular Question
after develop pictures found some
  • Photography
