20 Most Recent Microsoft Wireless Entertainment 8000 Keyboard Questions & Answers
I have the Microsoft Entertainment Centre 8000 and
Go to Youtube and watch the video of key placement on any microsoft keyboard but you need Eye piece (Lens) to clearly see the precision parts to repair, dont loose the plastic parts.
5/27/2020 11:20:35 PM • Microsoft... • Answered on May 27, 2020
Microsoft wireless 8000 slow movement
Do not use device causing issues. Incompatibility problem.
9/1/2017 4:31:45 PM • Microsoft... • Answered on Sep 01, 2017
3answers
MS Wireless Entertainment Keyboard 8000 - FN keys not working!
You can change in the keyboard program.
1/18/2013 11:39:12 PM • Microsoft... • Answered on Jan 18, 2013
2answers
I have a Microsoft Wireless Entertainment Keyboard
My MS dontle gave me nothing but problems, now I have two Belkin Bluetooth dongles, one covers a 10 metre range and is for a USB 1.1 connection, the latest one a 100 metre range USB 2 one.
The first one worked fine but thinking that my machine only has USB 2 sockets I installed the new 100 metre range one thinking it would be much better, but it wasn't it froze and had jerky movements so I came to the conclusion that it was picking up interference from someone mobile or computer.
So I ended up going back to the first one and it works great.
Try a friends Bluetooth dongle and see if it works better than the one you got with your keyboard, it might cure your problem as mine did.
You can get them for pennies on eBay.
8/2/2012 8:12:12 AM • Microsoft... • Answered on Aug 02, 2012
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
3/18/2011 11:45:27 AM • Microsoft... • Answered on Mar 18, 2011
Shift key keeps falling out and won't stay in even with the clip
try super glue or use tape
7/15/2010 3:19:17 PM • Microsoft... • Answered on Jul 15, 2010
2answers
Replace a broken space bar
djmc_moskito
In regards to getting replacement parts for a keyboard they really do not make those as they are cheap and most people just replace the keyboard when it breaks.
However yoou might try looking on sites like ebay to see if someone is selling a broken one for parts.
Let me know if you have any more problems or questions
Issken
4/14/2010 9:55:22 PM • Microsoft... • Answered on Apr 14, 2010
2answers
I have a microsoft wireless entertainment desktop
Try looking in your bluetooth places and see if you can add the keyboard by itself, if not remove the mouse/keyboard and try re-adding them both as a pair.
10/21/2009 11:45:09 AM • Microsoft... • Answered on Oct 21, 2009
2answers
There is a red and green led flashing, and the
This means it's lost its Bluetooth signal. Re-run the BT setup and you'll be fine
10/21/2009 11:42:02 AM • Microsoft... • Answered on Oct 21, 2009
2answers
I have Microsoft WED 8000, charging problem
well this is a technical issue contact your dealer immediately ..have it replaced
its the capacitor that has been affected...it is due to uneven current
10/18/2009 7:00:03 PM • Microsoft... • Answered on Oct 18, 2009
Installing Microsoft wireless entertainment 8000 Keyboard and mou
call microsoft at 1800-936-5700 I just bought my keyboard today and I was having issues. I returned the product and it seems fine now.. i havent fully charged it yet so I can fully use it.. Also when I was stuck at that same issue there is a bluetooth button underneath the mouse and keyboard hold it for 5 secs and it should connect with the computer and allow you to choose next and not just cancel... but like i said call microsoft and tell them ur problems
8/12/2009 6:47:50 AM • Microsoft... • Answered on Aug 12, 2009
I need a new dongle as i broke mine, did buy a
You can order replacement parts directly from Microsoft.
U.S. Customers can contact the Microsoft Order Desk at: (800) 360-7561 (Monday through Friday, 8:00 a.m. to 7:00 p.m. Eastern Standard Time)
6/11/2009 7:21:04 PM • Microsoft... • Answered on Jun 11, 2009
F-8 key
The F8 key is used to access your system recovery and repair options. When you restart your computer wait a couple of seconds and then start pushing F8. Hope this help, please feel free to leave feedback. Thanks
4/15/2009 7:45:45 PM • Microsoft... • Answered on Apr 15, 2009
Laser mouse 8000 won't connect to blue tooth
try to check whether the drivers are properly installed
3/16/2009 6:52:45 PM • Microsoft... • Answered on Mar 16, 2009
My Microsoft Wireless Entertainment Desktop
ENTER THE BIOS AND ENABLE SET-UP CONFIG. AND REBOOT.RICHARDM69
3/10/2009 3:46:39 PM • Microsoft... • Answered on Mar 10, 2009
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
Microsoft Wireless Entertainment 8000 Keyboard Logo
27 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
red green led flashing
  • Computers & Internet
