20 Most Recent
Canon PowerShot G10 Digital Camera Questions & Answers
I have a Canon G10.
Some canons have a switch inside the card slot....don't know if you can get at it but you can try things like a dental pick, a toothpick, etc. Be careful.
The best telephoto lens for this camera?
www.kenrockwell.com/
canon/g10.htm
Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
www.dcresource.com/reviews/
canon/
powershot_g10-review/
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
"cannot detect camera"
Have you tried installing the software and then rebooting the computer. Quite often that's all that's required for the computer to recognize the camera.
I'm having problems trying to transfer pictures
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
When switching camera on there is a blank screen
In settings, you might have switched off the image for when the camera starts. Turn it back on. Also, if that doesn't work, try deleting some photos or change the sim card or the battery itself, not charge it.
G10 how can i restart the camera?
Go into settings and scroll down, then click reset. You can manually reset it by replacing the sim card or pressing the button inside of the area wher the sim card is.
How do I put my info on the metadata of the camera
Go to legalZoom.com and sign in with your email. Fill out the questionnaire for your photo, then at the end you can upload your photo. It should auto save the image in the metadata of photos on the camera and computer you are using if it is done right.
How do i turn up the volume for the video
First you press func. set on the video you want to turn up the volume on. When the movie starts press the func. set again and push the up button for the selected volume.
