20 Most Recent RIM BlackBerry Curve 8300 Smartphone Questions & Answers
3answers
Blackberry 8300 Curve
Try to find it here schematic
9/26/2016 8:21:39 PM • RIM BlackBerry... • Answered on Sep 26, 2016
I cant get my whatsapp its been locked
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
9/11/2012 5:45:27 AM • RIM BlackBerry... • Answered on Sep 11, 2012
Hi, I am using Blackberry 8320
well usually with blackberrys there is an unlock pin in the box you got it in. if not, then you have to go to your network provider and ask them to unlock your phone. you will need proof of purchase (a receipt, or the box, and dont try using your friends if you cant find it, they check the serial number) to make sure its not stolen. then they will most likely wip your data. hopefully you have a memory card inside, and if you do, remove it before sending it in, because they will most likely wipe your data if its still in there.
good luck,
luke
8/25/2011 9:37:31 AM • RIM BlackBerry... • Answered on Aug 25, 2011
How to solve the App
App Error 523 is a software error, most often related a theme or third party application you've installed.
Follow these directions:
1) Make sure you have Blackberry Desktop Manager installed.
http://us.blackberry.com/apps-software/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life.
Just don't disconnect anything and let the lengthy process finish completely.
NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.
I hope this helps.....
Regards.
4/28/2011 6:32:50 PM • RIM BlackBerry... • Answered on Apr 28, 2011
How do i unlock my blackberry 8300?
You can unlock it from online itself from the website at a cheaper rate through solutions
3/9/2011 12:11:25 PM • RIM BlackBerry... • Answered on Mar 09, 2011
App Error 523 Blackberry Pearl 8100
you need to wipe the device with JL commander and reload the software using desktop manager
7/19/2010 10:23:08 PM • RIM BlackBerry... • Answered on Jul 19, 2010
3answers
Blackberry curve has error 529 code
Blackberry would not, but your Wireless Vendor would refurbish it, if it is still under the one year warranty. Blackberry does provide the software to wipe/nuke the software. This may be a possible fix for you.
7/12/2010 3:37:03 AM • RIM BlackBerry... • Answered on Jul 12, 2010
5answers
Is it possible to unlock a verizon blackberry
yes :) but i dont know anyone tha does it for free. we charge because it uses up a bit of our time and we take a few risks doing it.
7/10/2010 10:30:24 AM • RIM BlackBerry... • Answered on Jul 10, 2010
The screen keeps intermittently freezing, I have
flashing the software might help, at this point that must be the only solution...but i would say i need to know more about the problem, when the fault first occured, past histories of mishandling, how old the device is etc
6/15/2010 9:54:31 PM • RIM BlackBerry... • Answered on Jun 15, 2010
System error 394
The best thing I was able to find is this forum posting on crackberry.com. Looks like the consensus is that the device "is toast" when you get that error message. Try re-installing the OS (backing up first if possible) or if it looks like there's nothing left to lose try wiping it with this tutorial. Most likely you'll need to replace the device. If you can back it up (or have a backup) that would be best of course.
6/5/2010 1:44:25 AM • RIM BlackBerry... • Answered on Jun 05, 2010
Son dropped the phone now screen is unreadable,
You need a new lcd. You can find them on ebay for less than $20 and fix it yourself if you are so inclined. There are some sites out there where they will fix it for you. Or you can trade it in on another phone at sites like ours.
www.usedcellphoneshop.com
5/8/2010 1:32:06 PM • RIM BlackBerry... • Answered on May 08, 2010
My blackberry phone keeps freezing up and the
this can sometimes happen to blackberries. and there is not easy fix. there are applications for the blackberry that you just click on to do a soft reset. this program was created because of this issue. if this does seem to help and you don't want to keep resetting your phone, you might this about doing a wipe and starting from scratch. you might have downloaded a program that just is not working properly...good luck
5/4/2010 2:22:38 AM • RIM BlackBerry... • Answered on May 04, 2010
Track ball wont move when keypad lights are on
change the track ball ic
4/8/2010 12:58:03 PM • RIM BlackBerry... • Answered on Apr 08, 2010
System error 394
you need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work...also if the DM does not see your PIN, remove the battery from the phone then connect it again you should see BB PIN:UNKNOWN just click next and you should be good to go.
1/30/2010 7:29:04 PM • RIM BlackBerry... • Answered on Jan 30, 2010
When I sync with exchange calendar on my computer
it will not show that what you can do is change the setttings making sure that when it syncs that overwritten does not occur.
1/30/2010 7:28:39 PM • RIM BlackBerry... • Answered on Jan 30, 2010
My blackberry doesnt find my plantronics 520
most headsets work with blackberries you should look at the manual and see if can pair with the phone.
1/30/2010 7:00:52 PM • RIM BlackBerry... • Answered on Jan 30, 2010
My new battery to my blackberry will not charge
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like charging issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
1/15/2010 6:43:45 AM • RIM BlackBerry... • Answered on Jan 15, 2010
What dose app error 523 meen for the small bb
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Cell Provider for Hardware Support.
1/15/2010 6:18:45 AM • RIM BlackBerry... • Answered on Jan 15, 2010
0answers
Error 394
Be the first to answer 1/4/2010 9:18:47 PM • RIM BlackBerry... • Posted on Jan 04, 2010Be the first to answer
RIM BlackBerry Curve 8300 Smartphone Logo
Popular Tags
35 questions posted
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
when first switch new blackberry curve
  • Cell Phones
