20 Most Recent
Nokia 6121 Classic Cellular Phone Questions & Answers
Lock code
you have to get it flashed at a nokia service point to reset everything. code will then be back to 12345
I want to copy image from my phone to my computer
Connect the USB cable that came with your cell phone, connect it to the cell phone and then plug the other end of the cable into the USB port on your computer. The computer will see the cell phone as an external storage device, then open the photo folder and copy the photos to your computer.
I need puk to unlock my sim care
HiYou can get the PUK code by contacting your service provider with a request for the same.They will definitely send you the code.Hope it helps.
Hi my Nokia 6121c has
Hi, it is the software that has crashed and requires a full software reimage. The LCD ribbon cable must be replaced. You will need to take it to the repairers who can connect to computer and reload fresh image.
The cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it while you wait or the next day at the latest.
GoodLuck=)
How do i save a
MENU>PHONE BOOK>OPTIONS>SCROLL TO COPY TO SIM>SELECT>ALL
HELPFUL?
Can you take the screen
hi
you can take the screen from your phone. kindly contact your service provider to do this.. don't try to take you alone. this may cause your mobile phone gets damaged..
thank you
The witch is not working
If you meant watch, then open menu , open organiser and then clock/calender settings.
set the time and date and save. it must work.
The switch is not working
If this is the switch then you must get help to desolder and remove fromthe mainboard the old swittch and install a new one.
however is the fault is not the switch, then it must be connected to the nokia software to find tthe problem, can be hardware or software.
Nokia 6121c the keypad has stopped working can
may first check the keypad, then the keypad matt/membrane, and also the interface of the keypad... if everything is good, then the keypad IC maybe the problem that may require a cellphone technician to repair this...
