20 Most Recent
Samsung SGH-F110 Cellular Phone Questions & Answers
What is my unlock code?
You can unlock your mobile phone using the unlock code. it is the safest way to your mobile phone. using calculator, or some other method to unlock your phone it will results in damage to mobile phone. you can get the unlock code from this site
www.mobile-unlocker.com at reliable cost....
Under security settingasking to enter puk 2 number
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no
Go to the nearest service outlet of your service provider they can also help you.
Thereis no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
My phone keeps turning itself off and on again
Sounds like a bad battery connection. Try taking a white eraser to the prongs on the battery (rub them lightly) its supposed to clean the prongs safely without any damage. If that doesnt work you may have to buy a new battery.
TM PUK CODE
ask your service provider, they will give you the code PUK.best of luck!
Free unlock code for sgh-t528gsamsung sgh-t528g
Hapy New Year:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
