20 Most Recent HP Pavilion dv2715nr Notebook Questions & Answers
I got a hp pavilion dv 2500 i assumed had a bad charger port because the light would not turn on when it was plugged in. so i went ahead and bougt a new component for it, but still no charge. any othe
How old is the battery. It may not be holding a charge because it is so old. Try holding down F12 during boot up to see if it offers you a battery recalibration option. If it does, follow the on screen instructions to the letter. Best of luck
12/17/2012 1:24:02 AM • HP Pavilion... • Answered on Dec 17, 2012
HP Pavilion dv2715nr Drivers for Windows 7
tp://ftp.hp.com/pub/softpaq/sp45001-45500/SP45058.exe
If you have a copy somewhere of C:\SwSetup folder from Vista, you have all pre-installed Vista software for your model.Should find there HP QuickPlay,etc. This software will also work under Win7.
This Linkseems to provide the best thorough approach to getting those drivers installed & working.However, someone claims, on this forum page(last post on the page) that all you need to do is use the "windows online driver search" function, and it will handle all of the messy work of locating, downloading & installing.
4/30/2012 7:57:52 PM • HP Pavilion... • Answered on Apr 30, 2012
2answers
Keyboard does not work, you cannot type anything and touchpad does not work either
This could be a simple matter of a ribbon cable coming loose but since it effects two different devices on separate ribbons I would have to look at the motherboard as the cause. You are going to have to open the machine and check the connects and check for something spilled inside.
10/26/2011 5:14:44 AM • HP Pavilion... • Answered on Oct 26, 2011
2answers
How do I adjust the color, contrast and sharpness
You can use the "Fn" + F7 and F8 key from the key to increase the Colour and Brightness of the Screen
10/10/2011 4:32:50 PM • HP Pavilion... • Answered on Oct 10, 2011
2answers
MY SCREEN WONT COME ON.
keep pushing f2 repeat 4 with f2 on start up then change your start up command to f12.
1/26/2011 3:44:30 PM • HP Pavilion... • Answered on Jan 26, 2011
At startup, my HP laptop (running Vista) says
Hi there you need to format the operating system and install a fresh copy on the PC for solving the problem.
1/17/2011 5:02:12 PM • HP Pavilion... • Answered on Jan 17, 2011
reinstall your pc, not as repair modde but with new instalation mode, but your data at drive C: will formated, back up it first before you reinstall
1/17/2011 4:35:15 PM • HP Pavilion... • Answered on Jan 17, 2011
I stepped on my laptop screen and need to know how
Hi,you can purchase these online by visiting this site www.notebookparts.com when select the make and model,then select the product you wish to purchase.
1/4/2011 11:11:34 PM • HP Pavilion... • Answered on Jan 04, 2011
2answers
Need a new or used screen for dv2715nr
www.craigslist.org or www.computerpartsannex.com are good sites for replacement parts.
11/27/2010 6:11:16 PM • HP Pavilion... • Answered on Nov 27, 2010
0answers
Keyboard does not work i
Hi you need to change the settings for the computer for it to work without going into standby. I can give you the information for this, but you need to tell me what operating system are you using?, and if the keyboard stop working it is either the connection in the computer is not properly connected or you need a new keyboard.
7/26/2010 2:03:35 PM • HP Pavilion... • Answered on Jul 26, 2010
Screen back light turns on but nothing else is displayed.
please dial this no once for HP help 18004746836
5/6/2010 7:39:32 AM • HP Pavilion... • Answered on May 06, 2010
Can HP dv2715nr hibernate instead of being put on
  • Hi. "Yes," but putting the computer in the Hibernation State, can use up to 400MB of memory, and can be very "unstable to the system." You Can change the "Sleep, Hibernation, Wake-up...from the Start search window, Type Power, to open the Power Options. "If the solution helped, "Rating it is appreciated, thanks."
3/15/2010 2:49:20 AM • HP Pavilion... • Answered on Mar 15, 2010
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
3/12/2010 6:40:47 AM • HP Pavilion... • Answered on Mar 12, 2010
HP dv2715nr has a different serial number when I
Possibly.. I am not exactly sure on exactly how you aqcuired your "product info". But I suggest this: http://welcome.hp.com/country/us/en/support.html Click on the link I've provided for you. Choose to scan your system to get the Exact Internal Identification. Then compare it with the sticker. If it is Different, Go to this link http://welcome.hp.com/country/us/en/contact/phone_assist.html#section3 and it will provide the HP CONTACT NUMBERS. GOOD LUCK!! Lucky4lynn2 p.s. PLZ RATE ME, K? THX
3/8/2010 1:54:13 AM • HP Pavilion... • Answered on Mar 08, 2010
3answers
Won't turn on
try removing the battery then return it back in place and give it a try.
3/7/2010 9:58:50 PM • HP Pavilion... • Answered on Mar 07, 2010
2answers
I want to turn my
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
2/3/2010 6:59:47 AM • HP Pavilion... • Answered on Feb 03, 2010
My display works for a few mins then goes out, but
Depending on how handy you are... my friend ordered a replacement LCD screen for laptop and self-installed. Check ebay or other on-line sources for part.
12/29/2009 6:50:52 PM • HP Pavilion... • Answered on Dec 29, 2009
HP Pavilion dv2715nr Notebook Logo
Popular Tags
39 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
hp pavilion dv2715nr drivers
  • Computers & Internet
