20 Most Recent Toshiba Satellite A215-S5818 Notebook Questions & Answers
Open toshiba a215-s5818 case completely
old post, there are no fuses. fan yes, mobo yes, and more all things lacking a HATCH. 11 years old, no spring chicken this. and may have CCFL lamps. CCFL dead , LCD goes dead. as all did now. this old. seem you got the wrong manual. the Toshiba web site shows NO SERVICE manuals, free. that is why I never own them, I buy dell or hp, as they do have manuals, for sure. my sis has one, and i had to use youtube to find all screws and those dang silly hidden secret plastic snap locks. yah, toshiba's SUX. the users manual shows , hatch covers off. show memory swaps. then omg fails to show RTC coin cell removal, yah. my sis, i put in a new LCD display and LED conversion kit. and new SSD drive. and loaded fresh W10 on it, so... im not helpless. it runs fast and well but I personally hat Toshiba PCs. I buy USA when I can, so there is that. i can not find true and matching service manual but see A200 series, yes. (from non OEM sources) 240+ pages there. manualsdir.com has it. here is how many work (Dismantlment) all hatches off, and what is under hatch removed DDR, etc. look for screws hidden there. remove those. dvd drive out , and screws tricky hidden there or on upper lip there. yah. hdd out, see screws below> all screws on the bottom out. ALL> remove keyboard, if not all in one with plastic top, remove it then find screws there, (on some LP the heatsink/fan and pipe assembly must be removed now. (my HP this is fact) try to know that all a215 are not the same, so manuals harder to find due to that one fact alone, (not user manuals real service man's) the if stuck still the toshiba has those dang snaps. http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm I use cell phone plastic pry bars, looks like tiny plastic crow bar if you read the above it shows using guitar pick. step 14 those are a pain, for sure if you break the silly plastic locks. 23steps, there, 205. now the video, we always look here first, it is free. UTUBE. my guess you stuck at time stamp 3:00 guitar pick. laptops take great skills to service, no 2 models are the same is reason 1, and then ribbon connector broken, there are 3 ribbon locks. push pull wedge lock hinge lock. each type must be addressed correctly or damage is DOA end.
8/26/2018 2:01:42 PM • Toshiba... • Answered on Aug 26, 2018
How do you replace an inverter board on a Toshiba A215-S5818
have a look at this video it will show you how to open up the LCD screen and from there you can replace the inverter board https://www.youtube.com/watch?v=zz9zdlktONM
2/28/2015 3:28:53 AM • Toshiba... • Answered on Feb 28, 2015
Need recovery kit
Go online to Toshiba, contact customer support and the technical department.
4/20/2012 3:40:05 PM • Toshiba... • Answered on Apr 20, 2012
Monitor comes up black i can see the cursor but nothing else any ideas? it boots normally but once past the boot screen its all black with just the cursor showing
Nevermind the more I thought about it, your not getting to the operating system. The PCs used to say something to the effect of 'operating system not found' after the POST if it could not find a boot device. I think that's what's happening here, you have to go into to BIOS and see if it can detect the hard drive. When the laptop boots look for a message saying 'press F1 for setup' or something along those lines... if it comes up too quick to see start hitting F1, Esc, Del keys right after the power lights comes on, BIOS is usually one of those keys. Once in BIOS look for a 'devices' type tab and search for where it reads the hard drive If there's nothing there then its your problem, and you need to get the BIOS to autodetect it. Respond if you have questions.
1/12/2012 4:12:59 AM • Toshiba... • Answered on Jan 12, 2012
2answers
Satellite A-215 goes to black screen. Has always
Sometimes my laptop does this as well. It seems to happen more and more when it is warm. You might try putting something underneath it and ensure it is getting enough air flow. Once I started doing this, mine has been doing it less and less. Hope this helps.
Thanks,
Ben
4/20/2011 10:54:23 PM • Toshiba... • Answered on Apr 20, 2011
Satellite a215-s5818 laptop stucks on boot screen,
Go into your bios and set your disc drive as the first boot device. Then put in your windows disc and do a startup repair.
3/21/2011 2:28:37 AM • Toshiba... • Answered on Mar 21, 2011
Iv switched my toshiba laptop
sounds like hard drive
  1. determine what brand of hard drive you have.
  2. Go to that manufacturers support site.
  3. Download their self booting diagnostic CD iso image.
  4. Create the disk according to the instructions.
  5. Boot to the disk and run the most exhaustive tests available to determine if the drive is bad or not.
1/17/2011 8:29:00 PM • Toshiba... • Answered on Jan 17, 2011
My, almost 3 year old Toshiba, will go black,
Hi dave claudet
I suggest you check the motherboard, because these things happen due to over-heat.
1> clean the cpu fan and heat-sink on the motherboard.
2> if it still happens
do troubleshooting on the ram, processor and motherboard.
(Most likely a problem on the processor or the chipset on your motherboard)
* For the more serious maintenance, I suggest you get an outside line help *
thanks and regards
12/9/2010 4:09:18 AM • Toshiba... • Answered on Dec 09, 2010
I have a satellite A215 - s5818 It started
his is sound as though your power adapter is not charging your laptop battery and the battery is trying to preserve what power it has left to power up the screen as you demand but there is no voltage to do so.
1. you will need another power supply adapter from what you have describe here and or a battery replacement.
if you can possibly get an equivalent power adapter for your unit and connect it to see if you get power up then you need to replace the power adapter.
I hope this helps. Have a great day!
10/5/2010 7:34:30 PM • Toshiba... • Answered on Oct 05, 2010
System repair is coming up at startup and it is
try to do fresh installation
2/7/2010 5:52:39 PM • Toshiba... • Answered on Feb 07, 2010
Power to board, no lights, will not power up.
i have same problem
2/6/2010 5:15:42 AM • Toshiba... • Answered on Feb 06, 2010
3answers
Toshiba Satellite A215-S5818 boot then it goes off
hi
there I think you have picked up a virus which has secured your operating system.
even safe mode cannot be run it for u to retrieve your data.
give your machine a fresh installation. get and install a data recovery program and run fornated recovery for your data. if you have a recovery disk for your computer, you can use it for the reinstallation.
thanks
12/28/2009 9:18:39 PM • Toshiba... • Answered on Dec 28, 2009
2answers
Need to know adout the fan
The fan should work off of the bios
9/28/2009 4:01:23 AM • Toshiba... • Answered on Sep 28, 2009
A215 S5818 doesnt boot at all...
Hi there.
Remove the battery and try it on AC power only.
Post back with the results please.
Good luck and thanks for using Fixya!!!
2/20/2009 11:44:55 AM • Toshiba... • Answered on Feb 20, 2009
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
Toshiba Satellite A215-S5818 Notebook Logo
Popular Tags
23 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
monitor comes up black see cursor but
  • Computers & Internet
