20 Most Recent Sony VAIO VGN-NS140E/S Notebook PC Questions & Answers
2answers
Hello, My laptop will not start the windows
blue-gw42ordsyt3sl3dyidksgpsd-2-0.png In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information: •The stop error number, which uniquely identifies the error •The stop error parameters, which provide additional information relating to the specific stop error number •Driver information is available if the source of the problem relates to drivers Armed with this information, you are able to search online to establish the problem and hopefully a resolution. In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003. If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu. If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu. boot-gw42ordsyt3sl3dyidksgpsd-2-2.png To disable the system from automatically rebooting, take the following steps: 1.Click Start, right-click Computer, and select Properties. 2.Click Advanced System Settings. 3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings. 4.In the System Failure box, clear the Automatically Restart check box. These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list can be found on MSDN within the Bug Checks (Blue Screens) reference at https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
9/30/2020 12:50:54 PM • Sony VAIO... • Answered on Sep 30, 2020
Haw ca I add Arabic language to the lep top model
Please install the language pack go to control panel and regional setting and choose the language wanted it will,ask for the windows cd provide the cd
10/23/2013 5:19:00 PM • Sony VAIO... • Answered on Oct 23, 2013
0answers
I just need some kind
Sorry to tell you this and you might disagree but sony,s are the most expensive to service and have many non-user serviceable parts which destines them to the scrap heap when they fail or die-im sorry i can help you more.
7/18/2011 9:41:00 PM • Sony VAIO... • Answered on Jul 18, 2011
2answers
I have a SONY VAIO
go into your sound driver options and locate the speakers you are trying to use, weather it be external or otherwise. Make sure the volume is up (i know obvious but still)
rate yea?
7/8/2011 3:34:30 PM • Sony VAIO... • Answered on Jul 08, 2011
My skype cant detect my
Sounds like it might be driver related...try downloading Sony Drivers Update Utility and that should update all your drivers, here is a link to the download:
http://downloads.cnet.co.uk/view/utilities/sony-drivers-update-utility-39778254/
Hope this helps
3/19/2011 9:12:57 PM • Sony VAIO... • Answered on Mar 19, 2011
The battery cannot be read?
if the battery cannot be read try inserting another battery of the same caliber or try to remove the battery and plug the AC adaptor on your laptop. If problem persists, call SONY to replace your battery....
2/17/2011 2:16:32 PM • Sony VAIO... • Answered on Feb 17, 2011
Please give me driver labtob
The Camera driver is integrated with the Vista OS, so installing the Original ArcSoft WebCam Companion Software should resolve the issue with the camera. Here is the link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS140ES&upd_id=3790&os_id=28
To resolve the issue with the Function keys, reinstall the VAIO Event Services:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS140ES&upd_id=3951&os_id=28
Thanks!!!!
1/5/2011 5:20:13 PM • Sony VAIO... • Answered on Jan 05, 2011
The battery is not detected
  1. You must try to turn off your PC then detach your battery
  2. Try to turn it on after returning the battery back.
12/30/2010 8:19:29 PM • Sony VAIO... • Answered on Dec 30, 2010
Skype can't detect my webcam - Laptop model sony
If the imaging device is missing in the device manager, it is generally considered to be an hardware related issue. But, there are chances even in this situation the camera has worked after performing some troubleshooting steps:
Try opening the preinstalled ArcSoft WebCam Companion Software in the computer and check if there also you are getting the message, " Camera device not found".
If so then the issue may be resolved by reinstalling the Camera driver. In your case the computer uses inbox driver shipped with the OS. But, as it is Sony try reinstall the original ArcSoft WebCam Companion® Software from the esupport website.
If that also doesn't work, download and install the Camera driver:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS140ES&upd_id=4257&os_id=7
While installing the above driver, the computer may prompt an error this update is not for your computer model.
In that case, extract the setup file of the above driver using the Universal Extractor and then run teh setup, this usually works!!!!.
Download the Universal Extractor from the link below:
http://www.softpedia.com/dyn-postdownload.php?p=56951&t=4&i=1
Thanks!!!!
12/17/2010 5:42:54 PM • Sony VAIO... • Answered on Dec 17, 2010
2answers
VGN ns140e Screen
Your Graphics Drivers could be wrong,but it sounds more like the cable for the backlight or the screen ,you wont of change the cables when you put the new screen in did you.
press the plastic around the top of the key board & under the screen untill you find the piont where it gets worse.then remove the back panel & screen surround to see which cables under their.
But for the drivers you can get them free on my web site:
T-ComTech Comuters.com
10/20/2010 12:59:22 AM • Sony VAIO... • Answered on Oct 20, 2010
Ok when I turn on
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
8/20/2010 6:52:32 PM • Sony VAIO... • Answered on Aug 20, 2010
My note book model is vgn-ns140e ,and i changed
Might be the webcam is not supported by Windows 7 (yet). If it is, there should be a driver for it on the Sony website.
You can try using a driver finder program to locate a compatible driver.
8/8/2010 11:18:25 AM • Sony VAIO... • Answered on Aug 08, 2010
My speakers on my sony vaio vgn ns140e were
Do a system restore back to the last date they worked.If that does not fix the issue,see next step.
If it runs on Vista,go to the microsoft website and type fixit into the search.Select the fixit tool,select audio/sound issues,and run the tool.It might find the problem and correct it.If that fails,update the BIOS.If that fails,do a system recovery after you back up the data,if the speakers don't work after all of that,you might have a hardware issue.
Good luck.
6/30/2010 12:12:37 AM • Sony VAIO... • Answered on Jun 30, 2010
Language settings
  • Hi, to change the "Language" back to any language of choice, do the following; from the "Desktop Screen" click on the [Start] button, next in the "Start Search" window, type: language. This will take you to the { Region and Language Options} window, now you be able to change the Language back. "Rating the help, is a way of letting me know that you have solved the problem, thanks."
6/27/2010 4:13:05 AM • Sony VAIO... • Answered on Jun 27, 2010
I have a VGN-NS140 and it won't turn on properly
i think it just needs a factory restore, by reinstalling the operating system on a fresh copy. some laptops can do it automatically using the manual you might find the key combination.
ctrl f10
ctrl f8
depends on the make
6/9/2010 3:29:14 PM • Sony VAIO... • Answered on Jun 09, 2010
Screen has been switched off...how to swith on the
try pressing FN and F6 together while laptop starts up or contact the manafacturer for guidance
3/11/2010 9:03:43 PM • Sony VAIO... • Answered on Mar 11, 2010
Need software for web camera
HI
Install the same installation file for your web cam in xp or vista
in windows 7 too...
its a trick
in which we are installing this driver in windows 7
in compatibility mode
compatibility mode allows any file on previous versions of windows to be installed in windows 7
For that
>>right click on the file
select properties
check the compatiblity tab
select windows vista
and dont forget to check"Run as administrator"
and apply
Hope this will solve your problem
3/3/2010 12:43:50 AM • Sony VAIO... • Answered on Mar 03, 2010
2answers
I want to install linux and have dual boot to my
You can try this to get the bios to default value by removing the battery. remove it for 30 min the put it back .You must fully unplug any power cable during the process. Or look to the motherboard somewhere near your battery there should be a jumper placed in two pin.if there is no third pin just take out the jumper then place it back .if there is a thrid jumper just place it in 2-3 position then back to normal position .do not forget to fully switch off your pc or laptop.you run the risk of runing your motherboard if u clear the cmos with powered up motherboard.
12/3/2009 1:56:20 PM • Sony VAIO... • Answered on Dec 03, 2009
Sony VAIO VGN-NS140E/S Notebook PC Logo
29 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
battery not detected
  • Computers & Internet
