20 Most Recent
HP Compaq Business Notebook 2230s Questions & Answers
I can't reset my bios password
BIOS password can be removed using either of these two ways:1) Take you BIOS cell out for a while and then plug it in again and your BIOS password shall be removed. 2) You can also change your BIOS Jumper Setting. Generally the BIOS jumper resides on pin 1 and 2. You simple take it out and then plant it in on pin 2 and 3. Power on your computer and then power it off. Then change the jumper to default setting that is pin 1 & 2 and then once you shall power on your laptop the BIOS password shall be removed. The BIOS jumper resides on the motherboard and there is a marking on it stating "BIOS" which shall help you identify the correct jumper.
11/1/2012 5:07:23 AM •
HP Compaq...
Answered
on Nov 01, 2012
Hp2230s
HP Compaq Business Notebook 2230s - Reset bios password issues
12/7/2011 8:22:38 PM •
HP Compaq...
Answered
on Dec 07, 2011
Hi. I have an Hp
hello sir
send me the code from bottom of your laptop .. like this one CNU123ABC then ill send you pasword.. thanks
11/14/2011 3:32:57 PM •
HP Compaq...
Answered
on Nov 14, 2011
My laptop shows red cross
If the message says consider replacing the battery, I guess the battery
life is about to end.
Its good to replace the battery if you have used to laptop for more that
3 years now. Normally that is the max battery life.
However, if the laptop is new and still under warranty, you need to
contact your vendor for possible free replacement, since it is abnormal
for the battery to wear in such a short time.
Also make sure the replacement battery is perfectly compatible to your
laptop. Your vendor can guide you more.
I have replaced batteries in the past. Remove it from the laptop and get
the number off of it. Then you can go and Google the number to find a
reasonably priced replacement.
Hope this helps you.
6/11/2011 12:39:44 PM •
HP Compaq...
Answered
on Jun 11, 2011
How to removed the bios
remove the battery and power supply, open it, and take the cmos battery out. wait 3 minuts. boot it without the cmos, it will say password disabled. shut it down and put it back together. you're done!
2/2/2011 4:05:48 PM •
HP Compaq...
Answered
on Feb 02, 2011
Bios password reset
Turn the laptop upside down and start removing the plates one by one till you find a button cell about 3/4 inches in diameter. Remove this cell for a minute or so and reinsert after that. Your BIOS password would be reset to nothing. And in future please do not use any passwords as we all tend to forget them sooner or later.
1/28/2011 11:33:58 AM •
HP Compaq...
Answered
on Jan 28, 2011
I bought Hp 2230s laptop,
To reset the BIOS read the information from this
link.
In case of your HP laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
12/23/2010 11:29:06 AM •
HP Compaq...
Answered
on Dec 23, 2010
Forgot cmos bios password.
How do
link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD, because it's pretty hard to open it up as you mentioned. Follow instructions from above link and try Kill CMOS to wipe the BIOS.
12/23/2010 11:27:02 AM •
HP Compaq...
Answered
on Dec 23, 2010
Reset bios HP Compaq 2230s
link.
12/22/2010 8:35:06 AM •
HP Compaq...
Answered
on Dec 22, 2010
Some time my laptop is
sir your hdd has serious problem it batter to replace and dont save any important data on it...Thanks
10/16/2010 3:45:17 AM •
HP Compaq...
Answered
on Oct 16, 2010
My laptop is locked it
if is the windows lock administrator password press F5 and go to safe mode and remove password from control panel if is the bios password remove the battery from the motherboard for 5 second then put it back
8/19/2010 8:00:25 AM •
HP Compaq...
Answered
on Aug 19, 2010
