20 Most Recent
ASUS Eee 900 Notebook Questions & Answers
Computer shuts down after 10-15 min
Overheating
When the CPU overheats then it will shut down (i.e. thermal
overload) and won't boot up again until it has cooled down. If this is the
problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged
with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure
the vents are clear and dust free. Use a small brush and can of compressed air
to do this.
L becomes a 3
Turn off your number lock. You have the keys in calculator mode.
I want to change my asus 333 pc from chinese language to english
Which Operating System?
The display language is the language that Windows
uses in wizards, dialog boxes, menus, Help and Support topics, and
other items in the user interface. Some display languages are installed
by default, and others require you to install additional language
files. When you change the display language, it is changed for your user
account and is not changed on the Welcome screen. If you want to set
the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
Open Regional and Language Options by clicking the Start button , clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
Click the Keyboards and Languages tab.
Under Display language, choose a language from the list, and then click OK.
Want to reformat EeePC900 back to factory
When your system is start then hold f8 key and bios setting will be appear hear will you change your restore factory setting. Or when your bios setting will not open then hold delete button then it appear.
I am trying to type
Tony,
You will have to install Russian fonts to your computer. To do that type russian fonts ig google search window and press enter. You will be shown both, free and paid fonts for russian. Download and install to your computer and you are on.
Windows root system
If you can repair the windows then boot with original OS cd and follow the instructions that how to repair installed windows.
If this repair process unable to fix this issue then you need to install a fresh copy of Windows. But remember if you want to install fresh copy, you will be unable to access your previous data on your drive C:\
Best of luck.
Regards;
Hasan
Asus eee 900 wont kick in
is the scrren compartible?is the board working properly?why is the fan not working ?the connections were bad try doing them over again. good luck.
Very Slow
need to download adaware software and remove all spyware from system. Also run disk cleanup under the accessories and system tools tab
How to load new ssd for eee pc
By SSD I assume you are refering to a Solid State Drive to replace your existing hard drive. If this is the case you need to install the drive and then boot off the CD that came with your computer and reinstall the operating system. Note that all you old info will still be on the original hard drive but you can still access it by purchasing a 2.5 inch USB hard drive enclosure. When you plug it into a USB port it will be detected as a second hard drive.
Need to change language from
Well if you are using the operating System WinXP.
Click on start then to control panel then to Regional and language options then click on the language tab at top then click on details there is where you change the language.
Hit Apply to save the changes you do
Happy Holidays
Change language asus eee 900
Try this, this is the solution if you are running Windows XP:
To change the language used for menus and dialog boxes
Open Regional and Language Options in Control Panel.
On the Languages tab, under Language used in menus and dialogs, click the language you want.
Notes
To open Regional and Language Options, click Start, click Control Panel, and then double-click Regional and Language Options.
This option is only available in the Windows Multilingual User Interface Pack. If you are interested in this product, please contact the Microsoft office nearest you for more information.
Wd 11 error code:0xc0000034
The last line of your error message contains the solution:
"You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a disk or USB device), contact your system administrator or PC manufacturer."
Translation: Start up from the disk that came with your laptop and follow repair tool instructions (or contact the manufacturer to obtain a copy - which you may possibly need to purchase. If you are not under warranty this will possibly be at a reduced cost.) Look for a label on the bottom of your pc for a phone number for service if your equipment is not useable. Good luck!
7/21/2022 8:42:08 AM •
ASUS Eee...
Answered
on Jul 21, 2022
Keys all mixed up keyboard
check using the onscreen keyboard or you can also check with an external keyboard to see if the same issue occurs with those. if it does the issue could be a software related. you can go to device manager, under keyboards uninstall the Keyboard Device and restart the computer.
10/7/2019 8:44:22 AM •
ASUS Eee...
Answered
on Oct 07, 2019
