20 Most Recent Acer Aspire 5315-2153 Notebook Questions & Answers
What is the empowering key for? and how do i know its working?
Launch manager is a piece of software you need to install. If you don't already own it, then search for it in Google. If it is for corporate use, then contact your IT department or follow the standard procedure for getting the software installed.
3/29/2016 2:57:56 PM • Acer Aspire... • Answered on Mar 29, 2016
Password forgot
Computer Login password?
9/6/2013 1:47:12 AM • Acer Aspire... • Answered on Sep 06, 2013
All numeric keys not working
Check the settings in the BIOS to see if they are disabled. If the are not, use a portable keyboard to see if the number keys work. If they do, check the device manager to see what the keyboard is listed as. You can delete it from the list and have it redetected. IF that does not work, OEM says that you restore the computer to factory settings. If that fails then you replace the keyboard.
7/29/2013 1:48:16 PM • Acer Aspire... • Answered on Jul 29, 2013
0answers
Fan help need
Be the first to answer 7/23/2013 9:00:04 AM • Acer Aspire... • Posted on Jul 23, 2013Be the first to answer
Fan help need
I think due to system heat up your power supply is not working good. So you need to call the technician to repair the power supply of your laptop.
7/23/2013 8:57:14 AM • Acer Aspire... • Answered on Jul 23, 2013
Fan
It is simple you can use hands and feel the air if exhausts is working good then it means your fan is running well.
7/23/2013 8:54:15 AM • Acer Aspire... • Answered on Jul 23, 2013
Fan vibration, noisy fan
If this is from a desktop model via the harddrive, try to vaccume it out, lots of greasy dust cant get into the fan and housing. I learned the hard way when my fan seized up and started smoking burned up. If you are not comfortable take it to a pc repair store. You can try and open it up by removing the screws and see if buildup is the problem, be weary if you have n e type of warranty it can be null and void if you mess around "inside" of it.
2/10/2013 6:36:45 PM • Acer Aspire... • Answered on Feb 10, 2013
2answers
Is there some way that I can move the factory set partition in my hard drive on my Acer Aspire 5315-2153 Laptop?
There are several freeware programs that will allow you to change, move, convert, etc your partitions. Here is one that is relatively easy to use:http://partitionwizard.com/free-partition-manager.html
12/7/2012 10:42:34 PM • Acer Aspire... • Answered on Dec 07, 2012
How to install a new acer 5315 cd/dvd optic drive
remove old one insert new one then update drivers - thats allhere is disassembly video http://www.youtube.com/watch?v=-ZklRtY7QTE
11/15/2012 3:26:45 PM • Acer Aspire... • Answered on Nov 15, 2012
Cursor moves in a different area when typing. I can't pass a typing test like that.
The links do not work
8/17/2012 11:16:24 AM • Acer Aspire... • Answered on Aug 17, 2012
Restore a 2 time
and the problem is?
6/15/2012 2:44:26 AM • Acer Aspire... • Answered on Jun 15, 2012
I need to put together the C and D drive so I can have more memory on my C drive
You can search for partition Magig which you merge both drives together or resize any of them, be ware of losing ur data and do not explore too much, just merge or resize and click apply to setting to take effect and your windows will restart so changes take effect
5/15/2012 10:11:32 PM • Acer Aspire... • Answered on May 15, 2012
What is the button with the circle with a line on top and dot on bottom and flashes red mean
There are four Easy Launch buttons above the Keyboard. First one has a symbol of a circle with a line in the top, and a dot at the bottom.This is the Wireless communication button, and also is an indicator light.It enables, or disables the wireless function.Red light indicates there is no Wireless communication on.This is Acer Support > Acer Aspire 5315 series of Notebook PCs > Manuals download page,http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5315/Aspire5315ul.shtmlLeft-click right on the top file -Aspire 5310, 5710, 5710Z Users Guide ENRegards,joecoolvette
4/16/2012 11:22:18 PM • Acer Aspire... • Answered on Apr 16, 2012
What does the circle with the line on top and dot on bottom and flashes orange on my acer laptop mean
It's the Wi-Fi /Wireless indicator. Sort of like a satellite dish symbol.
4/16/2012 1:31:58 AM • Acer Aspire... • Answered on Apr 16, 2012
Acer aspire 7540 - 1284 wireless router
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
3/18/2012 5:30:55 AM • Acer Aspire... • Answered on Mar 18, 2012
How can I restore Acer
HI
YOU MAY BE ABLE TO DO IT THIS WAY
Go to
all programs
acer
acer recovery
in there hopefully there will be an option to
re install applications and drivers
i believe it may be in there
hope this has helped you
many thanks
8/2/2011 9:43:09 PM • Acer Aspire... • Answered on Aug 02, 2011
My computer will not shut down. I need to hold
Get a good anti-virus and a good Malware program and see if it finds a bug to remove.
http://shop.malwarebytes.org/lpa/342/3/7268/index_b.html?_kk=malware&_kt=5649af65-023f-45b8-acb9-a5990bcaa0a7&gclid=CJCTr_LtoqoCFaZd5QodYyNeVw
Also Microsoft a a goo trouble shooting site.
http://support.microsoft.com/fixit/
Also check for updates to the OS.
7/28/2011 1:16:55 AM • Acer Aspire... • Answered on Jul 28, 2011
Acer aspire 5740-5255 issues with
Hi and Welcome to Fixya!
If you're having an issue with the hdd or with windows, be sure to backup your files first before doing the restore.
First press Alt+F10 immediately after pressing the power button when you boot up the laptop. You will see Acer Recovery Management, select "restore system to factory default settings" then follow the instructions.
Hope this helps!
Takasashi
7/14/2011 1:25:29 PM • Acer Aspire... • Answered on Jul 14, 2011
Removed battery,unplugged power supply,held power
remove battery and hold the power button for 10 sec and its soft reset
6/26/2011 1:38:54 PM • Acer Aspire... • Answered on Jun 26, 2011
Acer Aspire 5315-2153 Notebook Logo
87 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
circle line top dot bottom flashes
  • Computers & Internet
