20 Most Recent Tissot Diver Seastar 1000 Auto Steel Large Bracelet Watch - Silver Dial T19.1.583.31 Questions & Answers
Tissot Seastar 1000 Does anyone know of a source
Tissot is Swatch. They do not sell parts! You need to contact the company OR where you purchased the watch.
http://www.tissot.ch/?mod=stores&action=search&search=&regions=2&countries=195&countryregions=&option=cs
10/12/2014 12:06:32 PM • Tissot Diver... • Answered on Oct 12, 2014
Just got the battery replaced on my Tissot Supersport Chrono and now the chronograph buttons do not work. Any suggestions before I take it to a authorized repair shop?
Take it back to the shop that changed the battery. They have slightly misaligned the movement to the case. With a watch as good as a Tissot it is better to use a Tissot authorised dealer. My Seiko goes from Canada to London, UK for service.
10/26/2022 10:42:31 PM • Tissot Watches • Answered on Oct 26, 2022
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase there is a sunken button between the chronograph start/stop and the winding crown. Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
9/18/2021 6:20:20 AM • Tissot Watches • Answered on Sep 18, 2021
2answers
Hi, I have tissot expert, when I changed the battery, all option work perfect but the screen to activate compass not working and the bip as well,maybe battery not suit the watch ?
It could be that you have purchased the wrong battery for your watch and you should take it to a person that repairs watches and jewelry then to figure out what type of battery that will work in your watch.
3/8/2021 11:53:37 PM • Tissot Watches • Answered on Mar 08, 2021
How to zero the dials on Tissot 1853 watch
The reset button may be defective
11/16/2020 8:15:42 PM • Tissot Watches • Answered on Nov 16, 2020
My Tissot 1853 suddenly started to quickly run forward for 4 seconds and then rest for four seconds, doing that constantly. Is there a fix for this?
Hi. Can I assume this is a quartz powered watch? If so, sometimes, if thger bettery is either old or has started leaking hen is causes misfires in the time regulator.. First step would be chasnge battery & resdet the watch & monitor it. If this does not work, then put it into a Tissot service centre. Ifts not a quartz movement, there is no fault in a mechanical movement really that could cause this. Hope this helps.
10/6/2019 3:28:08 PM • Tissot Watches • Answered on Oct 06, 2019
Hi I have a Tissot Seastar 17 jewels manual wind 1964 mens watch. It runs, but is looses about 1/2 hr a day. Sometimes if i leave it face up on the table. It will run on time.
From your description it could be the main spring is broken, or there is a gear and or bushing failure. You will have to give the watch to a place that can service your watch. If you contact Tossot customer support they can advise you.
4/29/2019 8:07:01 PM • Tissot Watches • Answered on Apr 29, 2019
How to open the Tissot PR50 back to replace its battery?
A water resistant watch usually has a back that screws into the case and seals with a rubber O ring. Sometimes the back can be very tight to unscrew so even with the dedicated wrench it is difficult to remove without damage to the case. The professional would disconnect one end of the bracelet and clamp the case into a special holder. Once a non-dealer has replaced the battery it is usual to discover the back isn't replaced as tightly as original - this is reflected by the usual warning the watch will no longer be waterproof. The only way to retain the waterproof or water resistant quality is to have the battery replaced by a dealer or manufacturer when it will be, if required, pressure tested.
11/5/2018 2:06:46 AM • Tissot Watches • Answered on Nov 05, 2018
2answers
Tissot lelocle is loosing too many seconds a day and second hand jumps several times between second 10 and 25. Is there anything broken?
take it back for a warranty inspection / repair or refund maybe it is not genuine brand but a knock off in which case the manufacturer would like to be told about
6/16/2017 10:25:59 PM • Tissot Watches • Answered on Jun 16, 2017
I was given a Tissot
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
5/2/2017 8:41:31 PM • Tissot Watches • Answered on May 02, 2017
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gerald_b9936683ef6d97c6
4/24/2017 7:39:02 AM • Tissot Watches • Answered on Apr 24, 2017
2answers
I have a Tissot 1853 Model No:T52148131, I want to know what battery type to use, because I lost the old one?
Sorry I can't directly answer your question. There are a limited number of batteries that fit watches and the quality of the battery is the most important to provide a good lifespan and be less likely to leak. Anyone who regularly replaces watch batteries will instantly know which type fits so I suggest you visit your local friendly watch and clock repairer who will fit a quality battery and replace the O ring if needed and all for a nominal fee. If local traders aren't used they will be lost.
4/16/2017 6:53:00 AM • Tissot Watches • Answered on Apr 16, 2017
Does the Tissot PR516 T044.417.21.051.00 use a battery? My second hand is not moving when i start the timer and the night vision is terrible.
Yes, it does require a battery. I believe a 394 is the correct one to fit, but I'd suggest you took it to a professional rather than attempt a battery change yourself. I hope this helps.
6/1/2016 11:50:43 PM • Tissot Watches • Answered on Jun 01, 2016
Tissot Diver Seastar 1000 Auto Steel Large Bracelet Watch - Silver Dial T19.1.583.31 Logo
Popular Tags
1 questions posted
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
Tissot Watches
  • Tissot Watches
Most Popular Question
tissot seastar 1000 anyone know source
  • Watches
